-   Lancer Engine Management / Tuning Forums (https://www.evolutionm.net/forums/lancer-engine-management-tuning-forums-175/)
-   -   4G94 N/A Build Vendor's & Part #'s (STICKY) (https://www.evolutionm.net/forums/lancer-engine-management-tuning-forums/589925-4g94-n-build-vendors-part-s-sticky.html)
JDM_CEDIA Dec 21, 2011 01:14 PM
Hope their can be a sticky on all 4G94 M/T or A/T N/A Build for our 2.0 Engines.
RRM:
P# Throw out Bearing 4G94
P# Stage 1 Camshaft 4G94
P# Headers (Exhaust Manifold) 4G94
P# High Performance Complete Head Gasket Kit
P# Bored Throttle Body 4G94
P# Forged Pistons 4G94
P# Lightweight Pulley 4G94
P# Bored Intake Manifold 4G94
P# Ported & Polished Complete Head Stage 2 4G94
AEM:
P# 21-434 Cold Air Intake
K & N:
P# 33-2105 Stock Replacement Air Filter
P# HP-1010 Oil Filter
P# 69-6540 Short Ram Intake
Injen Technology:
P# RD1830 Cold Air Intake (M/T ONLY!)
P# D-476-4 Replacement Air Intake Filter (M/T ONLY!)
P# IS1830P Short Ram Intake
P# X-1018-BR Replacement Air Intake Filter (A/T ONLY!)
Unorthodox Racing:
P# 070941304 Clutch Kit (M/T ONLY!)
P# 070941314 Clutch Kit (M/T ONLY!)
P# 070921310 Clutch Kit (M/T ONLY!)
P# 070931314 Clutch Kit (M/T ONLY!)
Competition Clutch:
P# 50512400 Stage 1 Clutch Kit (M/T ONLY!)
P# 5051-2100 Stage 2 Clutch Kit (M/T ONLY!)
P# 5051-1680 Iron Man Clutch Kit (M/T ONLY!)
P# 5051-2300 Stage 3 Clutch Kit (M/T ONLY!)
P# 5051-1680 Stage 4 Strip/Street Series Clutch Kit (M/T ONLY!)
P# 5051-0620 Stage 4 Strip Clutch Kit (M/T ONLY!)
P# 5051-1420 Stage 5 Strip Series Clutch Kit (M/T ONLY!)
P# 5051-0420 Stage 5 Clutch Kit (M/T ONLY!)
Clutch Masters:
P# 05-054S-HD00 Stage 1 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDKV Stage 2 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDTZ Stage 3 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDCB4 Stage 4 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDCB6 Stage 4 Performance Clutch Kit (O.Z Rally ONLY!)
P# FW-632-AL Flywheel (O.Z Rally ONLY!)
Weapon-R:
P# 950-129-102 Cold Air Intake Box (M/T ONLY!)
P# 826-111-101 Universal Reservoir 24oz Coolant Aluminum Overflow Tank
P# 826-134-101 Universal Reservoir Bottom Inlet Tank
P# 826-211-101 Universal Reservoir 180oz Short Coolant Tank
P# 959-111-104 Universal Torque Damper
P# 826-113-101 Universal 24oz Oil Catch Tank
P# 826-213-101 Universal 180oz Oil Catch Tank
P# 826-313-101 Universal Pro Tank Oil Catch Tank
NGK:
P# 5464 Iridium XI Spark Plugs
DC Sports:
P# CAI6001 Cold Air Intake System (M/T ONLY!)
Gates Racing:
P# K040305 Alternator V-Ribbed Belt
P# K040305RB Altenator High Perofrmance Blue V-Ribbed Belt
P# K050516 AC/PS V-Ribbed Belt
P# K050516RB AC/PS High Perofrmance Blue V-Ribbed Belt
P# 36238 Tensioner Pulley Belt Drive Pulley
P# TCK201A Timing Component Kit
P# TCKWP201A Timing Belt Component Kit W/Water Pump
P# T201 Cam Timing Belt
P# T201RB Cam High Performance Timing Belt Blue
P# T41212 Cam Tensioner Assembly Timing Belt Tensioner
P# KS13907 Cam Seal W/O Turbo Timing Component Seal
P# KS14671 Crankshaft Seal W/O Turbo Timing Component Seal
P# 22721 Upper Coolant Hose
P# 22720 Lower Molded Coolant Hose
P# HK9RB Radiator Hose Kit High Performance Molded Coolant Blue
P# 31428 Cooling System Adapter Cooling System Tester Adapter
P# 33987 O.E Thermostat 180 Degrees
P# 33661 Thermostat Seal
P# 42280 Water Pump Standard
P# 348562 Pump Seal Kit Power Steering Repair Kit
Fidanza:
P# 961436 Cam Gear RED
P# 961434 Cam Gear BILLET
P# 961439 Cam Gear BLUE
P# 229501 Flywheel 9.5 lbs.
P# 861000 Short Shifter (M/T ONLY!)
Spyder Auto:
TS-HE-ML02-C Headers (Exhaust Manifold)
Kamikaze:
MLH2004 Headers (Exhaust Manifold)
Magnecor Competition:
P# 47182 7mm Spark Plug Wires
P# 45182 8.5mm Spark Plug Wires
P# 40182 8mm Spark Plug Wires
Edelbrock:
P# 38123 Universal 70mm Throttel Spacer
Carbing:
P# CA 220 001 0 T Universal 0.6L Fitting Type Reservoir Tank
P# CA 220 002 0 T Universal 0.6L Hose Type Reservoir Tank
P# CA 206 010 1 T Universal 10mm Hose Fitting Oil Catch Tank
P# CA 206 015 1 T Universal 15mm Hose Fitting Oil Catch Tank
NRG Innovations:
P# EDA-500CF Universal Large Torque Damper W/O Bracket Gun Metal
P# EDA-501CF Universal Small Torque Damper W/O Bracket Gun Metal
P# OCC-100C Universal Oil Catch Tank Chrome
P# OCC-100BK Universal Oil Catch Tank Black
P# OCC-100WH Universal Oil Catch Tank White
Greddy:
P# 12004901 Universal Oil Relocation Kit
Perrin Performance:
P# ASM-ENG-6 00BK Universal Oil Catch Tank Black
P# ASM-ENG-6 00BL Universal Oil Catch Tank Blue
P# ASM-ENG-6 00RD Universal Oil Catch Tank Red
more coming soon..
02modlanceroz Jan 2, 2012 02:49 PM
very nice. any prices?
JDM_CEDIA Jan 11, 2012 06:30 PM
Sorry no prices... There's vendors on here and it's all competition on pricing...
coollol123 May 16, 2012 01:58 PM
Spyder Also Has Intakes...
