Egr off
Old Sep 19, 2016 | 04:03 AM
lexa609's Avatar
Egr off
Outlander XL 2.4 4B12
ROm ID 51420011
Read OP2
the program Ecuflash
How to disable the EGR is hanging error P0489?
XML for EcuFlash is just the easiest to it does not work.
Or maybe someone knows RomId firmware without EGR?
File Type: rar
Old Sep 27, 2016 | 01:17 AM
Wanchai Panpron's Avatar
Why you don't fix the valve ?
Old Sep 27, 2016 | 05:15 AM
lexa609's Avatar
car lancer x with a 4b12 motor ,egr valve not.
And the USDM Lancer x factory has EGR ?
Old Oct 3, 2016 | 12:48 PM
lexa609's Avatar
https://www.drive2.ru/b/455579345507844444/
Disabling EGR valve on 4B12 Outlander XL (Lancer x )
Quite simply when there is need XML file but if not then will have to think!
This XML 4B12 (51420011) as with the usr, you can also disable the rear oxygen sensor.
Quite a lot of cards but not all are correct.
<table name="DTC P0249 Disable 0xFEFF -> 0x7F01 Disable the EGR valve part1" category="Misc" address="98d50" type="1D" scaling="Hex16"/>
<table name="DTC P0249 Disable 0xE61E -> 0xF000 Disable the EGR valve part2" category="Misc" address="98d52" type="1D" scaling="Hex16"/>
To load was 100% necessary in the ecuflash settings to choose Elements 12 .
Deactivation of the rear oxygen sensor go to the ECU option - ecu options set#2 bit 1. rear O2 is 0, all now firmware Euro2 only have to store.
Mode23 for logging can also be enabled using the XML.
IFMode 0x23 #1
IFMode 0x23 #1
Domode 0x52
XML the links below the firmware itself did not put as many of them freely available.
https://yadi.sk/d/LGwpWDBlwA7jC
XML for Evoscan. (display settings, need to check)
yadi.sk/d/1nGaIDRdvs2F6
fireroasted
Aug 31, 2013 09:52 AM
4RETECH
Nov 5, 2011 02:32 PM
motocooney
Sep 19, 2011 04:10 AM
yellowevo82
Jan 6, 2009 02:42 PM
