Flashing Evo ROM on NA Lancer
Old Jan 22, 2019 | 08:55 PM
SalD's Avatar
I installed a turbo in my 2014 ES MT a while back and have been running on the NA ROM with some adjustments for fuel scaling. I finally got around to bench flashing a 2014 Evo GSR ROM today and I'm having problems with getting it up and running. Flashing completed without errors and the car will start, but it sounds like it's misfiring and doesn't respond to throttle input.
I'm getting error codes:
P0117 - Engine Coolant Temperature Sensor Low Input
P0132 - Heated Oxygen Sensor (Front) Circuit High Voltage
P0243 - Turbocharger wastegate solenoid 1 circuit
P0247 - Turbocharger wastegate solenoid 2 circuit
P0327 - Knock sensor circuit low
P0365 - Exhaust camshaft position sensor circuit
P1603 - Battery backup circuit malfunction
P2128 - Accelerator pedal position sensor (sub) circuit high input
P2229 - Barometric pressure circuit high input
Can anyone here help fix these error when flashing a GSR ROM on an NA Lancer?
Old Jan 23, 2019 | 06:09 AM
Biggiesacks's Avatar
have you compared the ecu pinouts to make sure everything is the same?
Old Jan 23, 2019 | 06:18 AM
SalD's Avatar
I can't recall any specific threads, but I saw on one of the Mitsu forums that pinouts were the same with the Evo having more stuff. Other turbo build threads say to load a GSR ROM and it'll be ready to tune.
Old Jan 23, 2019 | 08:44 AM
maybe try a different GSR rom ID? Something close to the year of your lancer, if that doesnt work then maybe older/newer
Old Jan 23, 2019 | 08:53 AM
SalD's Avatar
I tried the Tephra Mod V1 for 2010 and got the same results. I guess I could also try a stock 2008 ROM, but I don't think it would help. You're right that comparing pinouts would be a good next step, but I can't find any for an NA 2014.
Old Jan 23, 2019 | 08:55 AM
yah you have a bunch of circuit errors which instantly makes me think wiring.
