New Boost map Idea need thoughts!!!
Ok guys so I was talking to burner and it seems like everyone on here is having a few issues with the tephra map. I did at a point but then it just went away not sure how? But here is what I was thinking
Has anyone tried using the stock evo 8 rom but a modified version.... heres my idea can you go into notepad and enter in the ecu ?perphery? to keep the check engine light from coming on. and just enter a spot in for the knock light so pretty much it would be a shorter version of the tephra but since the lancer and evo 8 roms have almost the same characteristics from what I have seen. This should solve the 399 maf swap issue, Idling issue, and knock issue at a point. The only thing you would need to do is lower the timing a bit to keep your engine from knocking |
You know what would be easier is just redoing the xml so you don't see the tables you can't adjust anyhow.
Then making a set of base maps for the lancer community with an xml to use them you can just attach those to this thread if you wanted. |
Originally Posted by RoadSpike
(Post 9469463)
hopefully some day this comes through lol
