New Boost map Idea need thoughts!!!
Old Jul 18, 2011 | 04:13 PM
steven121's Avatar
Ok guys so I was talking to burner and it seems like everyone on here is having a few issues with the tephra map. I did at a point but then it just went away not sure how? But here is what I was thinking
Has anyone tried using the stock evo 8 rom but a modified version....
heres my idea
can you go into notepad and enter in the ecu ?perphery? to keep the check engine light from coming on.
and just enter a spot in for the knock light
so pretty much it would be a shorter version of the tephra but since the lancer and evo 8 roms have almost the same characteristics from what I have seen. This should solve the 399 maf swap issue, Idling issue, and knock issue at a point.
The only thing you would need to do is lower the timing a bit to keep your engine from knocking
Old Jul 18, 2011 | 04:55 PM
RoadSpike's Avatar
You know what would be easier is just redoing the xml so you don't see the tables you can't adjust anyhow.
Then making a set of base maps for the lancer community with an xml to use them you can just attach those to this thread if you wanted.
Old Jul 18, 2011 | 10:35 PM
steven121's Avatar
sounds good man anything to help the lancer guys
Old Oct 2, 2011 | 09:59 PM
burner67's Avatar
hopefully some day this comes through lol
Live4Redline
Jul 17, 2024 07:09 AM
domyz
Jul 27, 2022 11:54 AM
HornstarBU
Feb 26, 2018 01:23 AM
KevinD
39
Dec 24, 2009 06:42 PM
realrift
Oct 6, 2008 01:35 PM
