Tephra mod showing strange knock CEL
Hi Guys,
First of all a big thank you to Tephra for the time and effort he puts into the ecu mods
I have a 2005 AUSDM Evo 8 with 96530006 Rom ID. It is (sadly) stock except for drop in filter. Running 98 octane pump gas.
I have used tephra's version 5.10 mod and enabled CEL on knock. I have also enabled spray ICS on knock. All the settings for these are left on default.
With this I have been experiencing the slow CEL flash (ie. knock count 3-7) when just sitting there in neutral and revving the car past about 2500rpm
This also happens when rev matching on a downchange while driving. That is, when I am going to change down a gear, I depress the clutch and I blip the throttle and it revs above 2500 or so, the slow CEL will flash.
There is no CEL when doing repeated 3rd gear pulls to 7000rpm
. It only appears to do show the CEL on knock with no or low engine load?
This happens with using the the base maps and also with some modded maps that I have loaded as alternate maps.
Any thoughts on this would be hugely appreciated as this is causing me some concern. I have a Tactric 2.0 cable so unfortunately I am unable to log at this stage.
Cheers,
Rift.
. It only appears to do show the CEL on knock with no or low engine load?This happens with using the the base maps and also with some modded maps that I have loaded as alternate maps.
Cheers,
Rift.
Thanks for the replies guys. So I guess its real knock then if the evo's tend to do this at low load
03RRVIII: I think the AUSDM cars are tuned for 98 octane. There is a "98+ octane only" sticker on the inside of the fuel hatch.
It doesn't worry me because i think it is damaging the engine (hopefully isn't), but if it knocks when down-changing and free revving, I guess the knock counter will slowly count down from 255 and the ECU may get changed to low octane maps for no good reason?
Cheers,
Rift.
Cheers,
Rift.
DormantBeast
13
Jul 9, 2017 07:38 AM
