exaust/header issue
Old Dec 10, 2004 | 06:57 PM
nextgenerationx's Avatar
exaust/header issue
i have the kamikaze headers with a custom cat back. it hangs way to low, my high flow cat bottoms out every speedbump there is... anything i can do to the header or the exaust piping to raise it a lil?
Old Dec 10, 2004 | 07:05 PM
Dookie's Avatar
If I'm not mistaken, the kamikazi header goes all the way back to the cat right? If so, I'm sure it connects to those two rubber hangars the old flex pipe used to connect to right? Other than that, I wouldn't see why it would hang any lower than stock if what I said above is the case. Are you lowered at all?
Old Dec 10, 2004 | 07:23 PM
i am lowered but u can see the exauste hang lower than the sideskirts
Old Dec 10, 2004 | 07:25 PM
Dookie's Avatar
It might be the cat-back causing it. Are all the hangars connected in the rear? I think there are 3 of them...
Old Dec 10, 2004 | 09:20 PM
yes.. i think the kamikaze headers r the cause of it since it connects right to the cat.. nothing to do with the catback since its connected the cat and the cat hangs low cause of the headers
Old Dec 10, 2004 | 09:42 PM
Dookie's Avatar
Hmmm..I don't know then. First I have heard of this.
Old Dec 10, 2004 | 09:46 PM
anything i can do like cut the headers a lil or osmething i wanna raise the exaust like an inch or 2
Old Dec 10, 2004 | 09:55 PM
SIMSSEGA's Avatar
pics?
Old Dec 10, 2004 | 10:10 PM
Dookie's Avatar
Have you been around under the car to make sure thats what is scraping?
Old Dec 11, 2004 | 07:20 AM
yep
Old Dec 11, 2004 | 07:30 AM
blaze_125's Avatar
I've got the Kamikaze with downpipe, I'm lowered on Progress Springs and never had a banging issue. Did you attach the Downpipe's hangers?
Old Dec 11, 2004 | 08:17 AM
ur exaust doesn't hang lower? alot of pple told me kamakaze headers hang a bit lower
Old Dec 11, 2004 | 08:46 AM
blaze_125's Avatar
It might be a bit lower, but not as much as what you're describing here
Crawl under your ride and see if anything is missing
Old Dec 11, 2004 | 09:17 AM
everything is there.. it hangs alot lower.. like its noticable if u r behind me u can c my whole exaust pipeing...
Old Dec 11, 2004 | 09:49 AM
blaze_125's Avatar
Do you see the Downpipe, the center pipe, or the whole thing?
If you have access to a cam, let us see a picture
