y does it tick?
Old Jan 9, 2005 | 03:28 AM
dailylancer's Avatar
y does it tick?
what with the ticking sound that comes from some place under the hood?
Old Jan 9, 2005 | 03:31 AM
Sten's Avatar
Those are most likely your valves, they make this sound when "cold" It's all good our engines are cold start engines, they take a while to warm up and then purrr...
Old Jan 9, 2005 | 03:36 AM
Iamkar33m's Avatar
lifter valves... the mitsu engines are notorious for that problem. They dont cause harm tho, just an annoying ticking sound. Turn ur music up to drain the sound out, lol.
Old Jan 9, 2005 | 03:39 AM
Recon's Avatar
i get that but also about every min i here a buzzing sound, like an electric motor is moving something,.. what is that?
Old Jan 9, 2005 | 03:47 AM
Iamkar33m's Avatar
Your flux capacitor...
Seriously though... no need to worry about every single little noise the car makes. It's not like our car is supposed to run 100% quiet. If that wasnt the case then what is that loud grumbling noise that comes out of the pipe thats behind the car? It gets louder when i press the gas pedal and goes away when i turn the car off
Old Jan 9, 2005 | 06:01 PM
KillahB's Avatar
If you got lifter tick, then they need adjusting.
Old Jan 10, 2005 | 06:54 AM
Recon's Avatar
the noise is normal i know but i just want to know what the noise is.. everyone sek me what it is and i have no clue what to tell them
Old Jan 12, 2005 | 11:54 AM
Lancestuh817's Avatar
After my engine warms up I can hold it at 2K and hear something loose could that be a loose lifter or valve? But when I drive I don't hear it.
Old Jan 21, 2005 | 12:25 AM
4Gaijin63's Avatar
i get a whistle from my bored TB. very subtle tho.
EDIT: sheesh 2 years and only my 500th post
Old Jan 21, 2005 | 03:07 AM
clckwrkorang777's Avatar
Yeah my car ticks.... It sounds like it comes from inside the intake mani...
Plus if I shift it into Neutral (auto) it stops...?
Daniel
Old Jan 21, 2005 | 05:58 AM
Danno's Avatar
It is either valves or throw-out bearing dpeneding where its coming from. If you put your clutch in and it goes away its the throw-out bearing, if not its the valves.
Old Jan 27, 2005 | 08:32 AM
1/3Evo's Avatar
I have that same noise on my 5 speed lancer ( valve clatter at approx 2000-2500 rpm) its not my t out bearing either.
Friggin dealer will not do anything about it. They said its normal wich is a crock. I have an extended warranty up to 75k and I am about to do the 60 K warranty. I hope they find something when they do that. Cause mitsus and blown valves are a known issue.
Old Jan 27, 2005 | 08:43 AM
Alchemist's Avatar
"blown valves" please elaborate.
When I did my headwork and reinstalled my lifters, the hydraulic lift adjusters had mostly lost their oil. When I started the car the lifter noise was unbelieveable. It took a few minutes, but the little bastards finally filled with oil and are very quiet now.
If you're having excessive ticking, check your oil level. it may be time for a change anyway.
The other thing that's been put forward is excessive noise from the injectors. Possible, but I wouldn't then expect that that noise would go away above a certain RPM.
Old Jan 27, 2005 | 08:52 AM
ItsTheDriver13's Avatar
From: Danville, CA (it really is all about nor cal)
could be exhaust vibration fro ma certain tone durrign acceleration making somehting vibrate, sounding like a ticking noise.......(just helping brainstorm lol)
Old Jan 27, 2005 | 05:16 PM
iyi0521's Avatar
My throw out bearing is making all kinds of noise after only 30k. That cant be normal.
