Autometer Water Temp Guage ?
Old Apr 3, 2005 | 06:20 PM
kbadboy's Avatar
Hey guys i searched and cannot find any help on how to instal my water temp gauge and what wiring i need, i alson need to try and just tap into the existing temp gauge so i dont have a limp gauge?!
Old Apr 4, 2005 | 01:03 PM
kbadboy's Avatar
help
Old Apr 4, 2005 | 01:43 PM
rhyzin's Avatar
shouldn't use stock sensor. did it come with a sensor you can T in somewhere?
Old Apr 5, 2005 | 02:02 PM
livelyjay's Avatar
Boe told me to drill and tap the water inlet elbow. It's located on the front-drivers side of the car, at the top where the block meets the head. It's a $15 part from the junk yard, so if you screw it up, it's not going to break your pockets.
Go to Home Depot and buy the 3/8 NPT drill and tap set. Take off the elbow, drill and tap it. Put the sensor in the hole to make sure it fits nicely. Clean off all shavings thoroughly. Take the sensor that came with the gauge, put thread sealent (liquid or tape) on it, and put it in the hole you just drilled. Do not over tighten because you could mess up the threads because brass is pretty soft. Put everything back together.
Get an 18 gauge wire, put a fork connector on one end, hook it up to the sensor. Run the wire to the drivers fender, under the fender, through the grommet, under the dash and hook up your water gauge.
Old Apr 5, 2005 | 03:27 PM
rhyzin's Avatar
TA-DOW ! there ya go
Old Apr 5, 2005 | 06:24 PM
kbadboy's Avatar
wow nice but do i have to drill to install?
Old Apr 5, 2005 | 06:26 PM
lookslikeanevo's Avatar
Ta-dow....kris you and rick have been brining up old skool stuff.....
dats wigitywigity whack......j/k
Old Apr 5, 2005 | 08:11 PM
livelyjay's Avatar
You don't have to, but it's the best place to install the sensor. Don't be afraid to do it (if you are, I am assuming you are since you asked, the only other reason would be you don't have a drill). The other place I was going to install was by splicing into the heater core lines. Boe said the temperatures from those lines would read a lot lower than the true water temp in the engine. If you don't care, then you will need to make a trip to Home Depot any ways.
You need a 1/2 inch female tee fitting, two 5/8 barbs with 1/2 inch male ends, and a 1/2 inch to 3/8 inch adapter. Then just splice into the heater core line, which is the rubber hose next to the master cylinder going through the fire wall. The other way will be cleaner, and will give better readings though.
Old Apr 6, 2005 | 12:20 PM
kbadboy's Avatar
could you get a pic of yours?
Old Apr 6, 2005 | 01:55 PM
livelyjay's Avatar
Well, I could take a picture, but the problem is I don't have mine installed yet. I have been way too busy running back and forth to VA that I haven't had time to finish the install. I likely will not be able to finsih it until I get down to VA either. Sorry man.
