Auterra Dyno run
Old Sep 8, 2005 | 07:55 AM
blaze_125's Avatar
Auterra Dyno run
I previously dynoed on Auterra with a set weight of 3000lbs that came out with 126 and 129 hp. I rectified the weight to 2900 and here the dyno sheet:
Old Sep 8, 2005 | 08:31 AM
datdjrobp's Avatar
man, i need to get one of those things. the stats on the lower right, did you enter those yourself?
Old Sep 8, 2005 | 09:36 AM
blaze_125's Avatar
Yep. I'm not exacly sure how other dyno work, but since the Auterra makes up hp/tq number according to weight, temp, gear ratio and all that I figured I would write it down on the gif file. The gif file is actually a PrintScreen I imported in Fireworks because there is no such option in Auterra Which is the only flaw I could find so far.
Auterra is awesome. I already cleared my Check engine P0421 just about 10 times so far
Old Sep 8, 2005 | 09:56 AM
gregivq's Avatar
What's P0421?
Did you have a chance to check how accurate Autera is?
Old Sep 8, 2005 | 10:00 AM
blaze_125's Avatar
Originally Posted by gregivq
What's P0421?
P0421 is : Warm Up Catalyst Efficiency Below Threshold. (Header removing the first cat)
Alchemist has dynoed on a DynoJet and the difference was around 1% or 2% off.
Old Sep 8, 2005 | 10:21 AM
gregivq's Avatar
Sweet! Sounds like a great product. How did you come up with the gear ratio? Does 5.xxx means fifth gear? I'm not familiar with that stuff.
Old Sep 8, 2005 | 10:26 AM
blaze_125's Avatar
The Auterra software has a built-in tool that calculates the Gear Ratio. You drive in whatever gear you want between 3000 and 4000 rpm for a few seconds and it comes up with the Gear ratio of that gear. 5.088 is the 3rd gear ratio.
Later this week if the highway near my place is empty, I'll try to make a 4th gear pull. But it's got to be more then empty cause 4th gear takes the car to almost 125mph Ain't too safe on a busy road.
Old Sep 8, 2005 | 12:20 PM
redozrally's Avatar
125mph?!? I don't think I can take my lancer up to 120 mph in 4th gear...
120mph is like almost 220k/h and I'm normally at 5th gear my then....
Old Sep 8, 2005 | 12:26 PM
blaze_125's Avatar
Let me recalculate then
Nope. 200km/h is indeed equal to 124.27424(125)mph. And yep... 4th gear gear does bring you close to that if I remember correctly(between 185-200km/h).
http://www.megaconverter.com/mega2/
http://www.digitaldutch.com/unitconverter/
Old Sep 8, 2005 | 01:11 PM
N1te's Avatar
... u must have a very special transmission
Old Sep 8, 2005 | 01:27 PM
blaze_125's Avatar
And why is that? 4th gear isn't going any lower than 185km/h. But anyway. That ain't even the point. I need an empty road cause getting 4th gear to redline requires to be going way too fast for busy streets. And yes... you might be right. 4th gear might be slightly lower than 185km/h, I'm taking numbers from the top of head. I have been going that fast a few times, but not enough times to know exacly at what speed that gear cuts off at.
Old Sep 8, 2005 | 01:38 PM
N1te's Avatar
u drive a manual right? if it's an automatic your 185km/h could be right
Old Sep 8, 2005 | 02:30 PM
03RallyLancer's Avatar
yeah it seems like i remember my 4th ending around 115... i could be wrong though.
Old Sep 8, 2005 | 03:22 PM
rhyzin's Avatar
4th in a 5mt ends at 109 mph
3rd in an auto ends at 112 mph
4th in an auto ends at 153 mph
Old Sep 8, 2005 | 09:13 PM
eh i was close
