Spark plug change
Old Sep 17, 2005 | 09:20 AM
kenshinx001's Avatar
so stock plugs are only good for 100k miles?
Old Sep 17, 2005 | 09:31 AM
jeff's Avatar
owners manual says change every 30K id change around 40ish
Old Sep 17, 2005 | 09:35 AM
umm i have an off topic question... does changing the fuel pump decrease mpg?
gregivq's Avatar
I don't know how often you should keep your stock plugs. On the box from NGKs it says good for 100k miles. (if I remember correctly)
Just change them 30k miles and you will be fine.
Old Sep 17, 2005 | 09:39 AM
thanks (ty too jeff)
Old Sep 17, 2005 | 10:19 AM
gregivq's Avatar
Changing fuel pump will not decrease mpg, upgrading fuel pump will.
Old Sep 17, 2005 | 10:21 AM
Old Sep 17, 2005 | 10:25 AM
gregivq's Avatar
I think our stock fuel pump is 155lph. If you will get walbro 255lph you will decrease your mpg unless you will tune it.
Old Sep 17, 2005 | 09:33 PM
Nightblade128's Avatar
Denso's eh? Where can I order them from?
Old Sep 20, 2005 | 09:30 AM
krimson_binome's Avatar
Whatever you do choose to go with I would stay away from platinum tipped spark plugs. Since our car uses a wasted spark ignition system, two of the spark plugs fire from ground to electrode instead of electrode to ground. I have heard that this will cause the platinum electrodes to wear out prematurely. Just FYI.
