Emission Recall Notice 02-03 Lancers
Old Sep 22, 2005 | 10:06 PM
  #31
Lancerguy'03's Avatar
Originally Posted by AznFlip
Sorry OT: Hey Andrew, have ever been to Walker's Renton Mitsubishi? Because the shop foreman there told me that he serviced a turbo Lancer before.
no...
Old Sep 22, 2005 | 10:14 PM
  #32
4g94T's Avatar
Originally Posted by 03RallyLancer
why are you guys even discussing the 2nd cat... the first one what the recall notice is for...
i have a header, so im not affected?
Old Sep 22, 2005 | 10:15 PM
  #33
03RallyLancer's Avatar
no your not affected... but you can still go in and get the reflash... thats what i did... doesnt take very long b/c they dont have to check it... just reflash
Old Sep 24, 2005 | 04:05 PM
  #34
chummer-x's Avatar
I have an rrm header, do i have to put the stock one back on to do this recall????
Old Sep 24, 2005 | 04:18 PM
  #35
AznFlip's Avatar
No, even if your car is fully modded, they're going to service it no matter what .
Btw, if you have an aftermarket header/manifold and you're SES light is on, they will clear it for you, but expect to come back because your warm up/first cat is gone. The solution, is to relocate the 2nd o2 sensor, meaning drill another plug hole after the cat and put the o2 sensor there and close the first one, so that way, it will sensor after the cat.
Old Sep 24, 2005 | 05:03 PM
  #36
chummer-x's Avatar
thanx for your help.
Old Sep 24, 2005 | 05:24 PM
  #37
EarsLikenElf's Avatar
Im curious, do they even pop the hood when they do the reflash? or is it done from inside the cockpit?
----I was able to remove the CEL by using the 2 plug non-foulers, and drilling one out. (instlaling no the 2nd cat)----
- Andy
Old Sep 24, 2005 | 05:34 PM
  #38
yes the pop the hood b/c the have to check and see if the 1st cat is blocked up... they reflash through the obdII port under the driver side dash
Old Sep 24, 2005 | 08:43 PM
  #39
AznFlip's Avatar
- Andy
Where did you get the 2 plug non-foulers?
Old Sep 25, 2005 | 01:03 PM
  #40
chummer-x's Avatar
Thumbs up
local pepboy, i forgot the pn but get the 18mm size one (brand HELP!)
Old Sep 26, 2005 | 11:21 AM
  #41
chummer-x's Avatar
Talking
Just got the recall thing done, not a problem at all with all the mods on the car. so get it done.
Old Sep 26, 2005 | 12:14 PM
  #42
akasirlancerlot's Avatar
****in mitsu
Old Sep 28, 2005 | 08:56 AM
  #43
Dr Crash's Avatar
ok got the recall done, but they did NOT even pop the hood to check the pre-cat and when they did the reflash i have weird problems with my car now
when i'm driving and trying to shift gears, i release the gas and push the clutch, but the car keeps the rpm high for a couple seconds before letting it drop. and sometimes it even increases the rpm before letting it drop. never had this problem BEFORE the reflash and i've put around 35,000 miles on it. anyone have ideas on this one?
Old Sep 28, 2005 | 01:05 PM
  #44
chummer-x's Avatar
happened to me also, i think the ecu is trying to learn again. my car is fine now after a day.
Old Sep 28, 2005 | 01:06 PM
  #45
pull the neg battery cable and reset the ecu
