All you need to know: SPARK PLUGS!
Originally Posted by bagice
Don't run the Bosh 4+. I put them in my Lancer and felt the difference in a bad way. Switched them out for Denso Iridium's and they worked alot better. All the extra grouds on the 4+ just got in the way.
I had 4+ and then swiched to some regular Bosch. I could feel a loss in power (very minor) the first drive but then it was the same.
I want to get some of the iridium NGKs, but i have a question. Our car calls for .039-.043 gap, is this the same for iridium? Also, a friend told me some cars can increase the gap to run better, but then again he bored his 2L DOHC to a 2.25L, how whould you know to increase the gap?
why is sparkplugs.com giving me different plugs for 02 lancer and 03 lancer...i was pretty sure there running the same ones?!?!?!!?
i wanted NGK platinums and now i dont know which ones i should use?!?!!?!?\
______________________________
by the way...thanks for all the info...its sweet
Im bumping this because I ran into this same thing and it confused me to all hell. lol. 02 and 03 lancers on that site give different gaps even though they are the same car. The correct gap is .44 which is what you get when you input 2002 lancer. Figured I would answer this question.
Ok, OEM manual recommend NGK BKR5E-11 .044.. and the NGK website recommend..
*Standard BPR7ES .032
*OE Laser Iridium IGR7A-G ^ # .032
*Iridium IX BPR7EIX .032
..tried going local to shops for NGK's and they say they don't have them instock.
Should i just order them in Standard BPR7ES
