Air intake/CEL
Old May 23, 2006 | 06:45 PM
iufan4lifeul's Avatar
Air intake/CEL
I just installed a MAF adapter with a filter on it to my 02 Lancer ES and as soon as I started it up the CEL light came on. Do I NEED to reset my ECU? I would prefer not to but if that is what it takes let me know. I don't know if the seal is PERFECT on the gasket going to the MAF but it wouldnt leak much air at all... Car runs, idles, and drives perfectly.
Old May 23, 2006 | 07:03 PM
ambystom01's Avatar
Reset the ECU.
Old May 23, 2006 | 07:05 PM
should that fix the problem? Thanks for the response
Old May 23, 2006 | 07:09 PM
ambystom01's Avatar
It might, don't know till you try it.
Old May 23, 2006 | 07:31 PM
digdat's Avatar
also make sure that you have the sensor plugged in .. alot of people unplug that and don't plug it back in. then reset the ecu
Old May 23, 2006 | 07:34 PM
HAHA, funny you mention that. I started the car up and it sputtered a bit but I couldn't figure out why... Of course I had the sensor unplugged. So, disconnect negative battery, let sit for 15 minutes or so, hook it back up, let car idle for 10 minutes, take it out driving for 20 minutes or so of variable driving to reset the ECU I think?
Old May 24, 2006 | 08:13 AM
Just stopped by the place I bought the stuff from. He said that because I started it up without the MAF plugged in the ECU didn't find it when I plugged it back in so he just hooked it up to the computer and reset the code. Easy as that. The ECU reset would have done the same thing probably...
