Accolade - Stage 1 Cam New Price RPW Quality
Old Aug 1, 2006 | 07:13 AM
sdhes's Avatar
Originally Posted by TougeOZ_04
make something for the 04+
ROAD/RACE 4G94 STAGE 1 Camshaft. 02-06 Lancer
There is your 04
Old Aug 1, 2006 | 10:09 AM
ambystom01's Avatar
I'm sure the RPW cam will work on 04s as well.
Old Aug 1, 2006 | 10:29 AM
Alchemist's Avatar
4G94 is 4G94, right? IIRC the main difference is the 04+ doesn't have the returnable fuel lines and the first cat is welded into the start of the DP (or something like that), so everything else for 02-03 should also work for you guys- certainly internals, underdrive pulleys, etc.
I see sdhes is on the wrong side- maybe we can sway him to see the light?
Old Aug 1, 2006 | 11:03 AM
gregivq's Avatar
LoL, some like the dark side of the force.
Old Aug 1, 2006 | 05:01 PM
03RallyLancer's Avatar
NJ accolade... too bad im gonna be going for the stage 2... and too bad i just bought $600 or so in goodies recently.
Old Aug 1, 2006 | 05:39 PM
Mitsiman's Avatar
All of our RA lancer products fit the 04+ model. The only thing that does not go across is the fuel pressure regulator kit, but everything else turbo kits, headers etc all fit up to the 04+ model.
With the 04 models, they are like our australian models where the cat is fitted up permanent to the flex pipe.
Those vehicles woudl respond to our whole bolt on kit with cat converter which woudl fit up to the standard flange position after the factory cat converter.
Old Aug 1, 2006 | 06:12 PM
Kurt's Avatar
Back to my previous post, other than R&D and proven performance, I want a more specific comparision.
1. What is the cams duration?
2. What is the lift of the two cams?
3. It might be a bit early, but I would like to see dyno numbers for a car running your basic I/H/E setup and using RPW's cam and the same with the RRM cam.
Old Aug 1, 2006 | 06:36 PM
Mitsiman's Avatar
RPW camshaft specs have always been avaialble on our website in the FAQ/Techinical data section. Check that out for our specs. You will see there is a difference between our auto and manuel camshafts. ALso see the difference between a mirage and 4G94 camshaft
Old Aug 1, 2006 | 06:52 PM
Alchemist's Avatar
I can only post from the perspective of someone who has watched both companies over my 4 years here and has dealt with both companies. I don't want to jump your ish, but you're really asking a lot.
1&2) http://www.rpw.com.au/shop/index.php...=111&Itemid=25
# 3) that's asking a lot. RRM doesn't post dyno numbers so you're asking RPW to buy a competitors cam and dyno it- which they won't do because it's classless and only invites a war. Or you're asking one person to buy two cams and dyno both. That's a huge investment for any person or any company. RRM went and made ONE cam that's supposed to make power for both NA and FI Lancers whether auto or MT.
Originally Posted by Mitsiman
RPW Stage 1 camshafts are proven in the USA market with many people having them. Remember there is also an Auto and Manuel Model Stage 1 camshaft which was researched many times due to the Auto's being suspectable to idling issues.
This means that any generic cam that is being marketed for both manuel and auto models, is a very small profile to enable the auto's to idle properly. The RPW Stage 1 Manuel model camshaft is definitly larger and won't run in an Auto, but has been proven many times to produce maximun power for them.
Also we would definitly like to state, due to the larger profiles that RPW utilises for our stage 1 camsahfts etc, they ARE NOT COMPATIBLE WITH FORCED INDUCTION. Use of any of our naturally aspirated camshafts would not be beneficial with any forced induction. If you want a turbo camshaft, get a proper one which has the right duration / lift / valve overlap.
Old Aug 2, 2006 | 05:38 AM
Kurt's Avatar
Thanks. I know I am asking alot, but I want all the information that I can have before buying something that is going into my motor. Mitsiman, thanks for the info, and Alchemist, thanks for the link. I know I am ask alot with my third request, but I like to have all the information that is possible.
Thanks again.
Old Sep 20, 2006 | 12:54 PM
frank boogie's Avatar
i want to see some dyno results with the cams
i have had the cam for awhile and never got it installed until i get the engine beefed up and i am waiting to hear how many horses i will get
Old Sep 20, 2006 | 01:10 PM
Alchemist's Avatar
Oh sure, they'll get someone right on that The gain is going to depend on your setup and how you're tuned. Dyno numbers from one car to another don't mean bupkis.
Dang, I could have just quoted myself again
Old Sep 20, 2006 | 01:29 PM
gregivq's Avatar
I'd just like to see more dynos in the dyno thread...that's all.
you could of qouted yourself in this thread lol
Old Sep 20, 2006 | 01:33 PM
krnzzang84720's Avatar
nice price for the cam!!! I guess this came is only for NA manual??
so not for the FI??
