Question for People with Filled Motor Mounts
Old Jan 2, 2007 | 12:42 AM
N1te's Avatar
Does anyone else notice noise from the engine rocking on the solid motor mount? I have a poly-filled motor mount and whenever I go from a dead stop or shift, you can hear a noticeable squeak from the engine shifting on the mount. Is anyone else's' car noisy after replacing just the front one?
Old Jan 2, 2007 | 12:45 AM
DRFTKNGG's Avatar
The powerflex are cheap, make no noise and will not fail. with just the front filled, you have now put all the stress and load on the rear. Give FORGE a call. They have all of em. Makes a big difference in how the car feels. Great bang for the buck! Reliablility is key.
Old Jan 2, 2007 | 10:38 AM
ROCK's Avatar
None of them should make noise. The stiffness of it may cause you to hear something else though. Try to isolate the source of the noise.
ROAD/RACE
Old Jan 2, 2007 | 03:19 PM
Blacksheepdj's Avatar
Rob said it best. It's probably something else making noise now that you stiffened up the motor mount.
Old Jan 5, 2007 | 01:06 AM
N1te's Avatar
It's squeaking everytime the engine moves. I'm not sure what else it could be other than the mount =\
Old Jan 5, 2007 | 08:47 AM
Could it be a different mount? There are four, after all. Or maybe it's loose? Try tightening the bolts a bit...
Old Jan 16, 2007 | 12:36 PM
02 OZrally's Avatar
i filled my motor mounts and yes u will hear a small squeak but thats normal cuz ur engine is stiff
Old Jan 20, 2007 | 09:00 PM
Elvis's Avatar
i get a squek during engage/disengage. could that be from the stockmount. maybe its shot? motor jerks alot to.
