SOHC to DOHC??
Old Apr 8, 2007 | 10:36 PM
Spoz2435's Avatar
SOHC to DOHC??
hello everybody.. i have a 2003 lancer es and i want to swap the single overhead cam to a duel.. i have the DOHC cylinder heads but what i want to know if there is anything i need to do to my engine in prep to installing the DOHC cylinder heads. thanks
Old Apr 8, 2007 | 10:53 PM
ambystom01's Avatar
Easy, buy the right engine for it.
Old Apr 8, 2007 | 10:58 PM
Spoz2435's Avatar
i have the 4G94 Engine block. and that is the same block as the evo.. so in my mind swapping the sohc with the dohc cylinder heads should be an easy task but i wasnt sure if it would fit nicely. I wasnt sure if the internals would line up nicely either. im just curious if i need to do anything to the engine before hand.
Old Apr 8, 2007 | 11:00 PM
yellance's Avatar
since when is the 4g94 the same as 4g63
Old Apr 8, 2007 | 11:01 PM
Spoz2435's Avatar
oh... lol thats a good question, im obviously wrong. well in that case would the dohc cylinder heads fit on my block?
Old Apr 8, 2007 | 11:04 PM
ambystom01's Avatar
That is not the same block as the evo. We have the 4G94, the evo is a 4G63, the only thing we have in common is displacement. The DOHC head you have is useless, get rid of it.
Old Apr 8, 2007 | 11:06 PM
Spoz2435's Avatar
are there any dohc cylinder heads that would fit my block then? or is it not worth it to even look for it
Old Apr 8, 2007 | 11:07 PM
newimportowner's Avatar
Dump it.
Old Apr 8, 2007 | 11:12 PM
ambystom01's Avatar
I think there are some DOHC heads that will fit the 4G94 but they are extremely rare, ie. you cannot get them outside of Australia, Japan and the surrounding region. As I said before, get rid of that 4G63 head, it is useless to you. We don't drive hondas, cross-compatibility is rare and complicated with mitsubishis.
Old Apr 8, 2007 | 11:13 PM
ambystom01's Avatar
As for worth, what do you actually want to do to the car?
Old Apr 8, 2007 | 11:14 PM
Spoz2435's Avatar
ok thank you very much for the help.
Old Apr 8, 2007 | 11:18 PM
Spoz2435's Avatar
well i want to eventually turbo my lancer. i would have loved to convert it to evo but that is too much time and money and just a complete head ache. so what i plan to do is full exhaust, turbo, obviously intake, swap the internals, suspension/brakes, basically to make hooked up enough to really enjoy it lol
Old Apr 8, 2007 | 11:20 PM
Spoz2435's Avatar
i just figured dohc would make my car run a little nicer than sohc when i turbo it. a quick question with the turbo. if i want to push 15-20 psi where should i aim for my compression ratio.
Old Apr 9, 2007 | 06:19 AM
Silens's Avatar
wow you're just trying to make our day eh? , ill be nice and say that you need to go to this section, and read A LOT since you seem to know nothing about the car you own, and searching helps too.
Old Apr 9, 2007 | 12:45 PM
ambystom01's Avatar
If you want to push 18 PSI, you need a lot of engine work and probably a standalone ECU. By engine work I mean new pistons, rods, ported and polished head, new camshaft, new cam gears, new valve springs, etc.. If you want to drop the compression I'd go for 8.5:1. 7.5:1 is too low and you'll have no power out of boost.
