WORKS - 2008 Lancer
Old May 9, 2007 | 01:54 PM
OliSim's Avatar
WORKS - 2008 Lancer
WORKS has been feverishly developing products for the 2008 Mitsubishi Lancer. Products in development include:
WORKS Ride Springs
WORKS Exhale Exhaust Systems
WORKS High Flow Air Filter and Intake
WORKS Brain Flash
WORKS Wheel and Brake Packages
WORKS Interior Parts
We wanted to share some pictures of the WORKS Ride Spring package that will be available within the next month. We will be able to take pre-shipments starting May 20th. Please give us a call if you have any questions or comments.
Sincerely,
The WORKS Team
415-226-2500
info@worksmitsu.com
Old May 9, 2007 | 09:39 PM
gts_in_nj's Avatar
will the exhaust be axle-back or full catback?
Old May 10, 2007 | 11:31 AM
OliSim's Avatar
Images not Diplaying...
We are working with EVOm to fix this problem. In the meantime, here are the links to the images on another server.
http://www.givegas.com/images/IMG_1862-em.jpg
http://www.givegas.com/images/IMG_1866-sm.jpg
http://www.givegas.com/images/IMG_1872-sm.jpg
Sorry for the inconvenience...
Sincerely,
The WORKS Team
415-226-2500
info@worksmitsu.com
Old May 10, 2007 | 07:23 PM
LancerGTS's Avatar
I'd like to know this as well, if you could please respond to it next time?
Old May 11, 2007 | 07:32 AM
OliSim's Avatar
The first WORKS Exhale product will be an axle back. More for sound than all around power, since the Lancer doesn't generate much gains when the muffler is removed. We are also working on a more comprehensive exhaust package that will allow our Flash to be fully utilized. More information will be coming soon.
Also, there will be some more comprehensive modifications offered as well, so we will keep this board posted.
Thanks,
The WORKS Team
415-226-2500
osimons@worksmitsu.com
Old May 15, 2007 | 06:45 PM
gts_in_nj's Avatar
bump for updates. how are the engine mods coming along??
Old May 16, 2007 | 10:30 AM
08Icelancer's Avatar
any pics of the intake you made??
Old May 16, 2007 | 03:55 PM
gts_in_nj's Avatar
do you have an idea as to when any of your products will be avaliable?
Old May 16, 2007 | 07:26 PM
jRox's Avatar
^^ same question
Old May 16, 2007 | 07:32 PM
YoungMoney45T's Avatar
will the springs be for the de or gts.....or is the suspension the same on both?
dont have an 08, but seems like a helpful question
Old May 17, 2007 | 04:18 PM
OliSim's Avatar
Greetings,
As of right now, we will have springs for all Lancer models. The spring rates might be different due to the change in weight between models but we will test that when we get our final springs for the GTS. Thanks for the question.
Sincerely,
Oliver Simons
WORKS
415-226-2500
Old May 17, 2007 | 04:58 PM
gts_in_nj's Avatar
Originally Posted by OliSim
Greetings,
Sincerely,
Oliver Simons
WORKS
415-226-2500
all i hear about is springs...how are the other products coming along?
Old May 24, 2007 | 08:12 AM
08Lancer89's Avatar
got any pics?
Old Jun 14, 2007 | 06:27 AM
Melaz425's Avatar
Is your project lancer a 5 speed or the new CVT?
Old Jun 14, 2007 | 05:46 PM
OliSim's Avatar
Greetings All,
We are finalizing several other products for the 08 Lancer. Here they are in no particular order: Swaybar, Cold Air Intake (with or without battery relocation), Exhaust (Axle Back and later Cat Back), and Flash. We are also investigating options for a Low PSI Turbo Kit. Also, there will be some trick interior parts available later this year.
Our Lancer (mine) is a CVT since the ECU is a bit different than the manual for development purposes.
We will share more information as it becomes available.
Cheers,
The WORKS Team
415-226-2500
info@worksmitsu.com
