trottle po sensor and egr valve
Old Jun 30, 2007 | 09:07 AM
02yellowozlance's Avatar
i changed my fuel injectors and know my car is running like crap i had my computer tested and it says its the egr valve and the trottle body sensor does anybody know if
the fuel injectors would cause it
Old Jun 30, 2007 | 10:07 AM
coal's Avatar
Did you just replace straight across for stock injectors?
If you went larger then you most likely need to get tuned for the increase.
Old Jun 30, 2007 | 05:18 PM
they was supposed to be the same but they were orange instead of white
Old Jun 30, 2007 | 10:16 PM
coal's Avatar
I dont know if color makes a difference. I think you should contact whoever you got those from to confirm they sent you the correct item.
Old Jul 1, 2007 | 02:36 PM
i put the old ones back in and now it runs better than before
