Future Mods. RRM, other vendors, anyone.
I'm not sure if I want to do F/I. I kind of would like to keep it N/A. I've done turbo with my SRT-4 and GSX, now I want to build strong N/A.
So with: Piggyback or new ECU, pulley, exhaust, intake, header, high flow head, cams, injectors, throttle body w/spacer, and what every else you can do you a N/A. Could I hit 200hp or more?
I know the 4B11 is a new motor, but we can all agree that it's not a V8. People with fully-modded 4G94 motors saw minimal gains. Granted, no one has had the exact list you have, but I just don't see 200 hp coming N/A. Maybe someone will prove me wrong...
I got a question about how a F/I system will be implemented with the MIVEC.
Will the MIVEC need to be disabled due to the cam settings or can you just engineer it to work with the MIVEC.
I don't have a specific concern about one thing, just a funny feeling that there is more to it then just bolting it up and letting it run.
The concept of the MIVEC will still be valid, however, a controller would be nice in order to maximize the gains. Typically aftermarket manfacturers will remove the variable timing when they design new cams for simplicity. These new cams are designed to perform well in a certain rpm range.
Highly doubt it.
You guys need to understand that this is a DOHC... unlike the SOHC. This will allow for a lot more tunning options and gains than a 4g94. Also, with aftermarket parts coming out for the EVO X, I'm pretty sure we'll see 200+ HP N/A.
a k20A3(rsx and civic) honda N/A can easily push 210 and if im not mistaken have less chp than the 4b11 stock. So untill someone runs a full N/A setup(possibly with ITBs) we wont know if it will do 200hp or not. Also with the changing of rev limits and balancing the engine i dont see why this couldnt be turned into a high revving N/A beast
I have a request for a couple mods, keep an eye out and PM me if you see these please and thank you
+Short throw kit
+Different side markers, the stocks just look cheap
+different antenna for the car (maybe one like the new GM's or BMW's?)
+Short throw kit
how long do they take for development if you have any experience with them.
and is this them?
http://www.twmperformance.com/
Yes, that is them. They didn't give me a time frame, but the tech said that the 08s setup if fairly similar to the older Lancers. So they might be able to just use the 06 Lancer short shifter. IDK. He said they were going to try it out.
