engine stumbles
Old Aug 2, 2007 | 05:49 PM
forgsix3wannab's Avatar
ok....called rrm they emailed me another wiring diagram for the piggy...reinstalled reset ecu and piggy and..........drumrolll.......still pops...i dont know about how hot it runs but i still get mas code.Im thinking im gonna have to replace it.....
Old Aug 2, 2007 | 05:51 PM
ambystom01's Avatar
Just take the damn thing off! Jesus, if something is screwing up your car, don't put it on. Take it off, reset the ECU and see what happens. If the code is still there, it's not the piggy, if it goes away, it's the piggy.
Old Aug 2, 2007 | 05:52 PM
does anyone know if my compression is good? 1.180 2.165 3.167 4.165 .....and if that why would cyl 1 be higher than the rest?
Old Aug 2, 2007 | 05:54 PM
ok ok ill be back in 20 mins to see if anything changes. Crossing fingers.
lancerrally45's Avatar
what kind of compression are you talking about?
Old Aug 2, 2007 | 05:56 PM
ambystom01's Avatar
He say's it in post 18. That sounds about right but the deviation is somewhat unsettling, I'm not sure what the cutoff is before it's considering a blown motor but that's close.
Old Aug 2, 2007 | 07:21 PM
ok i took off the piggy and it runs fine no check engine light no pops and it purrs like akitten. too good actually..it idles soooooo quiet sounds like its stock but when i get on the gas it comes to life....would make a very good sleeper if it was fast.i dont get it why would the piggy do this?
Old Aug 2, 2007 | 07:44 PM
kungfugirl's Avatar
cuz u need to sell it buy a wideband, datalog and tune ur car using openecu.
Old Aug 2, 2007 | 07:50 PM
whaats open ecu? datalog?
Old Aug 3, 2007 | 06:45 AM
Blacksheepdj's Avatar
OpenECU is a free program that lets you tune your car DIY using only a laptop and a OBD2-USB cable.
There's a LARGE thread in our Lancer Engine Management forums about ECUFlash, might be a good starting point. Read it here.
Datalogging is the act of hooking your laptop up to your car and using a program to LOG the DATA that your ECU records. The ECU in your car is constantly tracking data about everything from engine speed to water temp, etc.
Honestly, I'd remove the piggyback. It really doesn't seem to be getting along with your car. You could buy the software from RRM and take it to a tuner to see if they can make it run better or you can just sell it and move on. That part is up to you.
wwevoxx
Sep 26, 2014 04:20 PM
GEARS
46
Jun 6, 2006 10:28 PM
ashumo
12
Oct 27, 2005 10:03 PM
Secret Chimp
31
Jan 31, 2004 12:14 PM
mis4tun81
45
Sep 13, 2003 06:46 PM
