RRM Crank Pully Installed
Old Sep 20, 2007 | 08:48 PM
evodreamer01's Avatar
finally i got RRM's Crank Pully, install is not hard w/ the right tools. i'll recommed it to any one.
Heres a pic on the final product ( car still on the lift )
took me a while because i kept taking off the wrong bolts, but i finally got it down
Old Sep 20, 2007 | 08:50 PM
Green_Bandit's Avatar
Nice! Keep modding it man!
Old Sep 20, 2007 | 08:56 PM
alt jam nut
the bolt i couldnt find was the alt jam nut so here a pic so ppl dont pull off the wrong things like me
car is on a lift so your looking up from underneath, its behind the alt
Old Oct 21, 2007 | 04:25 PM
uci.magilla's Avatar
How long did it take you?
Old Oct 22, 2007 | 03:55 AM
eivelvenjacoby's Avatar
Guest
how much hp does that give?
Old Oct 22, 2007 | 04:13 AM
Lumpy's Avatar
It doesn't give any hp, but that doesn't mean it's not worth it. Think of it more as a supporting mod. It allows the engine to rev more freely. I'd say it's definitely worth it if you have an automatic.
Old Oct 23, 2007 | 11:58 AM
What do you mean by rev freely? i'm not to familiar with the part, but I have herd that it reduces the strain on you engine from other components like AC and power steering.
Old Oct 23, 2007 | 01:20 PM
trufleshufle13's Avatar
simply put, it doesn't give you more HP (any new HP at least) .. it just lets you feel more of the HP u already have
Old Oct 23, 2007 | 01:23 PM
with that in mind was there a noticeable difference with after installation. I've been browsing around through a few different brands. just trying to scope out the best one
Old Oct 23, 2007 | 01:24 PM
lancer2show's Avatar
cool, i still need to buy 1 of these.
Old Oct 23, 2007 | 03:22 PM
02-Lancer-Es's Avatar
so is there a diff in acceleration that is worth buying it? and what did u use to remove the stock one out??
air tools?
Old Oct 23, 2007 | 04:39 PM
Do you notice more HP at the wheels? Or Does it make the engine go thru revs faster?
Old Oct 23, 2007 | 05:25 PM
lancerfreak311's Avatar
i installed mine during my turbo install since i was down there, so basically it was a night and day change, probably like, 60-70hp to the wheels..... Just with the install of my pulley....a little help from my turbo. Just a little.
Old Oct 23, 2007 | 05:26 PM
ya im sure it will help for turbo i can feel a little more strain at the belt...not too much
Old Oct 23, 2007 | 07:06 PM
kungfugirl's Avatar
Well if i can reason it out, The pulley is lighter and so it allows you to rev more freely and therefore climb faster up the rpm's.
So you can reach boost faster
