help with intake
Old Jan 23, 2008 | 04:23 PM
jessiec132's Avatar
help with intake
ok well i went to pep boys and bought a filter and a map sensor adapter plate and made a custom intake it looks like the rrm intake. my problem is that wen i drive i felt a lose of power at low rpms wen i was driving so i took it off and also it made like a poof noise once wen it was on. so i was wondering wat the poof noise was and if u think it cause any damage to my engine. 1 more thing wanted to know if this lose of power happens wit every intake or was it just that it was just my cheap intake? thank u
Old Jan 23, 2008 | 04:34 PM
WangMan's Avatar
You shouldn't have felt a loss in power. Was your MAF sensor connected after you put on this "make shift" intake?
Old Jan 23, 2008 | 05:04 PM
jessiec132's Avatar
to be honest it was but it was at angle because i couldnt get the bolts to line it up straight... so wat i did i unbolted and put it straight and taped it down but i still felt the lose of power wat do u think... also wat do u think that poof noise was?
Old Jan 23, 2008 | 05:26 PM
Eagles GTS's Avatar
the poof is just the intake sucking in the air. You definitely shouldnt lose any low end power with an SRI. I would be careful with your MAF. Those things are really expensive.
Old Jan 24, 2008 | 04:42 PM
GTS08's Avatar
look I bought the same thing and I began to install it and i had problems in the installation process do you have any pics of your intake ??? mine did not fit on the sensor adapter?
Old Jan 24, 2008 | 06:21 PM
rody_mr's Avatar
its the maf its not the wright housing
Old Jan 25, 2008 | 06:44 AM
GTS08's Avatar
so I wasted my money ???
Im mean there has to be a way to connect the adapter cauze hnestly the intakes ae high on price and Im dealing with low budget
Old Jan 25, 2008 | 06:58 AM
Blacksheepdj's Avatar
How would we know? You just gave a rough description of your problem, didn't post pictures, etc.
Why didn't it fit on the adapter? You can't get help unless we know what's wrong.
Old Jan 25, 2008 | 08:25 AM
SeRious08's Avatar
How is $60 too much for an intake that works?
Buy a Mazda 3 2.3L intake off ebay. With slight moddification it will work like a champ.
Old Jan 25, 2008 | 07:38 PM
GTS08's Avatar
no I mean other brands the intakes that are out now
Old Jan 25, 2008 | 07:39 PM
GTS08's Avatar
nop sorry know it fits I did not installed properly but thanks anyway
Old Jan 26, 2008 | 12:43 AM
WangMan's Avatar
if you've got to use tape to make sure it fits, then it's not installed properly imo
Old Jan 26, 2008 | 07:37 AM
Blu_lite's Avatar
You might have done this already, but i would double check the direction of your sensor was it installed (with flor or against flow).
Old Jan 26, 2008 | 08:36 AM
evo_soul's Avatar
what brand intake is it? this is why i never understand. If you buy something and it doesnt work, dont mess with it, just return it or call the manufacturer.
Old Jan 26, 2008 | 04:32 PM
evo-monstar's Avatar
"bummer a nother loss to the pepboys guys"
