Need OEM Mitsu Part numbers...
Old Jan 27, 2008 | 07:02 PM
sykou's Avatar
Preparing for the install of the following; Pistons, camshaft, and camgear. I'm wondering what else I need to replace when doing the install. Planning on purchasing a full Ajusa gasket set(head gasket, valve cover gasket, valve stem seals, intake/exhaust gasket) might get a MLS headgasket dunno yet. And also Ajusa head bolts.
Is it necessary to replace the conrod bolts, rod bearings, and camshaft oil seal when I do the install? Im just worried about how much wear they might have on them....My car has 45k miles on it now by the way.
Old Jan 28, 2008 | 06:18 AM
senate6268's Avatar
Forget the head bolts. Switch over to ARP head studs. You can also switch out the stock conrod bolts for ARP rod bolts. Since you'll have it all apart anyway you might as well put in new bearings and cam seal. An ounce of prevention now...
