A New Take On Intake
Old Apr 11, 2008 | 09:40 AM
asenduy's Avatar
sweet idea
Old Apr 11, 2008 | 09:46 AM
lpxaudio's Avatar
does the drop in intake filter make a noticeable difference in sound?
Old Apr 11, 2008 | 10:02 PM
Blacksheepdj's Avatar
Nope. Sounds just like stock.
Old Apr 27, 2008 | 12:43 PM
lan08's Avatar
Originally Posted by Bradley_J
Do you have pics of this?
http://s265.photobucket.com/albums/i...urrent=167.jpg (click if it isn't showing)
just go to a Pep boys and ask them for airducts. The only hard part about the custom CAI is you need to build custom housing to hold the filter steady (use bushings or it will sqeek). I know it has ridges but if you know physics if yhe intake housing at the beggining is only 2 or so inches and the rigged airduct is 3 you are not loosing airflow. (i use to have a RRM SRI but i live in texas so i changed to a CAI.)
Old May 5, 2008 | 09:16 AM
gnnr's Avatar
Couple things when making a custom FWI type intake with ducts (I have done it with an 04 GrandPrix GT2).
-YOu gotta have enough room in your fenderwell for your selected filter.
-The tubing is flexible, but there is a downside... it's turbulent, which depending on your intake setup and other factors may negatively impact performance.
-Obviously the tubing needs a pass through from the engine bay to the fender area (Forward or behind your wheel)... if you don't have a spot big enough you may have to cut, and given the engineering of these things for energy management in a crash that may not be entirely safe to do (maybe).
- Your MAF and any other sensors inline with your air intake need to be maintained and installed in a similar fashion/attitude as with the original intake.
- The more bends the more turbulent and less effective the airflow of the intake (though given the stocker and it's bends, probalby not a big deal).
- As with any FWI, hydrolock is an issue (drive through deep enough water, like a deep pothole or flooded street and suck water in to the engine).
- If there is a spot where your filter is going to get the dirties, it's in a FWI.
Old May 8, 2008 | 11:45 AM
lan08's Avatar
get a hydroshield. I have one. But yeah i had to do no cuts, just driling in the housing to hold the weight of the filter.
rayman0690
Jan 4, 2026 07:20 PM
kraig
Lancer Engine Management / Tuning Forums
11
Apr 22, 2009 04:14 PM
wags528
Lancer Engine Tech
25
Feb 18, 2007 06:52 AM
Hiboost
Sep 1, 2006 06:21 AM
pinoyesv6
Sep 3, 2002 08:43 AM
