To cold air intake or not to cold air intake?
Old May 3, 2008 | 02:25 PM
MitsuNewbie's Avatar
Question To cold air intake or not to cold air intake?
Hello All,
I've got the upgrade bug in me and wanted to know something about Cold Air Intake for a 2006 Mistu Lancer 2.0L.
Should I put in a Cold Air Intake system and replace my stock?
Will I notice a difference?
Is a Short Ram Intake any better or worse for this model?
Will I benefit from this upgrade in anyway increase power, increase or decrease gas millage, etc....?
Thanks
Old May 3, 2008 | 03:02 PM
WangMan's Avatar
I've got a cold air intake but I'd say a short ram is more economical and you'll see the same gains. It won't increase much but you'll feel a bit more power.
Old May 3, 2008 | 03:04 PM
sgand's Avatar
$35 for a SRI and call it a day. Both will see the same.
Old May 3, 2008 | 04:30 PM
WOW, a $35 SRI!!! WHERE FROM?
Old May 4, 2008 | 02:07 PM
shinbumee's Avatar
$35 are the cheap ebay stuff.. not good for your car.
I've tried once, i don't know why but after a decent driving, the filter was displaced from the MAF sensor. It happened many times. so i threw it away also the filter suxxx~
I have K&N typhoon which is really nice
Old May 4, 2008 | 03:33 PM
Momak's Avatar
For the 2.0L, the cold air doesnt really make much of a difference, especially compared to the SRI. I guess the way I see it, it depends on how much you're willing to spend. Short ram is cheaper, easier to put in. But if you like the thought of having the CAI in your car, you COULD spend that extra.
Old May 4, 2008 | 03:36 PM
Momak's Avatar
oh. forgot to say. Gas mileage improves a bit, and supposedly you get a bit of extra power as well, but it's not really noticeable. Also, the CAI might be more fun to install, depending on the type of person you are.
Old May 4, 2008 | 04:28 PM
sgand's Avatar
WTF are you smoking. There are quite a few of us with DIY SRI, with ZERO problems. And it's not eBay. $10 MAF adaptor plate and $25 "Power Adder" cone, or K&N if you want for $30 more. Both can be had at Pepboys.
I'd strongly advise against the Typhoon. It is nice, but you get the same results as a DIY, which makes it a big waste of $$$.
Old May 4, 2008 | 04:30 PM
sgand's Avatar
That's the only reason I put a SRI in. I got 50 more MPT.
Bottom line is this. You're not going to get any power results whether you go SRI or CAI.
Old May 4, 2008 | 04:34 PM
sgand's Avatar
From a member here....
4" filter from autozone, with Spectre P/N 81403 MAF Sensor Adapter and Used
1/4"-20 x1-1/2" screws to secure the adapter to the MAF Sensor
Old May 5, 2008 | 06:10 AM
Question
All are good suggestions, I will install one just for the benefit of better gas millage, and if i get the extra boost which i don't count on, then even better!
BUT ONE MORE QUESTION.
If a a CIA is designed for cold air and the benefits of fresh cold air into the engine, What benefit does an engine have by using a SRI? Would this blow hot air from the engine compartment?
Old May 5, 2008 | 06:11 AM
Talking
THIS PIC IS PRETTY FREAKIN' SWEET!
Old May 5, 2008 | 06:24 AM
sgand's Avatar
Our motors do not have the power to feel a difference.
Old May 5, 2008 | 06:52 AM
Kurt's Avatar
To search or not to search? That is the question.
This is a well covered subject. You will have your fans of the CAI and your fans of the SRI. Each one has strong points and each one has weak points.
Closed.
McRooster
Jun 9, 2017 11:35 PM
jayden2306
Jan 26, 2017 06:05 PM
RedEvoxGSR
Jul 27, 2016 02:45 PM
studioface
May 31, 2016 07:06 PM
initialD
Lancer Engine Tech
24
Mar 11, 2004 10:47 PM
