Is their an oil filter that lasts 10-15k miles?
i just bought a purolater filter and i know they last up to 7.5k miles at the most. i was just wondering if their was one that lasts up to 10k miles. thanks
**edit**
i just bought like 12 quarts of mobile 1 ep. this is the oil im going to use.
**edit**
you dont want to wait that long to change you oil. exspacially if your turbo as the turbo heats the oil alot putting it through more damage. 5k at most for oil changes i would rec.
seriously man, take care of your car. I use synthetic and am unboosted and change it between 3 and 5 thousand miles, never later than that. Changing your oil regularly goes a long way
i should of mentioned im using mobile 1 ep. their oil is good for 15k miles. i just bought the purolater filter today and i was going to change it at 6k regardless. i was just curious if their was an oil filter that lasts as long as ep oil.
oh I felt scared all the time right when i hit 3k for oil changes. I also change my oil filters after every oil change. i never knew the limit of how long I could actually use oil and oil filters. Good info to know
your right. the amsoil ea filter is rated up to 25k miles.
http://www.amsoil.com/a/nanofiber-synthetic-oil-filter
Guaranteed for 25,000 miles or one year when used in conjunction with AMSOIL motor oil in normal service.
