Help and Advice
Old Mar 19, 2009 | 12:18 PM
taylor25's Avatar
Help and Advice
Hey All,
Need some theories from some of you seasoned guys. In my 02 OZ, in 2nd and 3rd gear, between 2000 and 4000 RPM, there is like a "stutter" that shakes the car while acceleration. 1st, 3rd, 5th gear is fine, and with the two problem gears, below 2000 and after 4000 is no problem. All the ignition coils/boots, wires and plugs have been replaced. Gapped correctly. CAI is clean, and after the last tune up, there was an O2 sensor replaced. Injector cleaner (Lucas) was applied to the last full tank.
I'm pretty much at a loss here. Any ideas on what could be causing that problem?
Thanks for all of your help!!
