dyno testings
Old May 19, 2002 | 04:04 AM
yellowlancerOz's Avatar
dyno testings
has anyone dyno thier lancers to see what hp they are running to the wheel??
Old May 19, 2002 | 04:53 AM
OzLancer.2's Avatar
No but in import tuner they dinoed one it sayed around a 103 horses.....that of course if u r stock
Old May 19, 2002 | 05:57 AM
what month in import tuner was it
Old May 19, 2002 | 06:01 AM
pisetup's Avatar
I believe it was last month
Old May 19, 2002 | 06:14 AM
cnile51's Avatar
May issue it was on the site... im trying to find it myself but its in the may issue
NiLe C.
Old May 19, 2002 | 06:23 AM
cnile51's Avatar
I did a lil reasearch for ya and since my goal on this forum is to help people and be helped i found you guys the article in the import tuner may issue 02'. Do me the favor of voting in my posts and replying in mine if you can... at least help me choose which wheels i should get and why lol
heres the link:http://www.importtuner.com/archives/...2_tech01.shtml
NiLe C.
Old May 19, 2002 | 06:39 AM
ok i will...thanks for the link to the article
Old May 19, 2002 | 09:55 AM
bahamut's Avatar
"The available horsepower also rose with the addition of the basic bolt-ons, and this leads us to believe that, assuming the block is built sturdily, there is plenty of power to be extracted from this 2.0-liter engine."
What the hell import tuner saying "assuming the block is built sturdily"? The block is sturdy since it shares the same block as the 4g92 MIVEC. 4g93T, and the 4g94. With TC on the block, it will hold. The only thing that won't hold is the conrods (way too thin for TC application), stock head gasket (not strong enough to hold the psi), pistons (wasn't meant to be TC for high or creeping boost), and connecting pins. The cyl head will survive unless extreme lean condition.
Old May 19, 2002 | 11:06 AM
ROCK's Avatar
ROAD RACE Turbo
We dynoed our TURBO LANCER back in November. The turbo was basically in earliest trim. Literally everything stock except turbo a 5 psi. Car made 148 h.p at the wheels vs. 103 stock. Car still had both cats and stock exhaust, stock T.B. etc... That was with baby turbo off a turbo Mirage. New setup with T-28 should more than outdo that even at same 5 psi.
ROAD/RACE
http://www.roadracemotorsports.com/
Old May 19, 2002 | 07:40 PM
Pimpson's Avatar
Rob, can you do any larger boring than the 4mm??? I really want a new throttle body but I want a b.i.g.
Old May 19, 2002 | 07:42 PM
HobieKopek's Avatar
NOTORIOUS?
Old May 19, 2002 | 07:45 PM
Pimpson's Avatar
P Diddy or Didn't he? Where's Brooklyn @?
Old May 19, 2002 | 08:18 PM
ROCK's Avatar
T.B. is 4mm almost 5. That is max stock t.b. will allow for because of the way it is made. We bore it right to the limit.
ROAD/RACE
Old May 19, 2002 | 08:29 PM
Pimpson's Avatar
thx. Since RRM most likely has designs for downpipes already any plans on new camshafts or some boring options for the 2.0?
Old May 24, 2002 | 02:06 AM
LancerLot's Avatar
Exclamation i don't now
wtf, they say the lance only has,,,,what 120hp???
i know for a fact that they down graded the car just so there copetators wont out do them,
cause i raced a mits eclipse the other day that had about 150 ibelieve he said...and i wooped his ***** ***!!!
thanks all
