spark plugs
Old Apr 17, 2009 | 10:51 AM
undercoverpope's Avatar
spark plugs
Hey i saw this on the net for a few extra hp.
Modification Number One: Index Your Plugs
The next time you are doing a tune-up on your ride, be sure to take note of this modification. By simply installing your plugs in a particular way, you will pick up roughly 1 whp, dyno proven time and time again.
As illustrated above, in order to perform this mod, mark the side on which the "open end" of the spark plug faces. Proceed to install them as you normally would, except when the plug is hand-tight (that is, you've screwed it in without a ratchet as far as it'll go), use your ratchet to tighten the plug until the open end of the plug, faces the intake side of your cylinder head. That's it!
Modification Number Two: Insulate Fuel Lines
Under-hood engine heat is a serious performance robber in almost all cars. Not only does the under-hood heat cause performance loss by heating up the intake air, but it also causes performance loss by heating up the fuel lines. Cooler fuel will help cool the intake charge, as well as provide for a better overall mixture.
In order to get this stolen power back, simply go down to your local hardware store and purchase a roll of refrigerator and air conditioning insulation. Wrap all of your under-hood fuel lines with the insulation to keep the cool in, and the hot out.
Modification Number Three: Relocate IAT Sensor
In most fuel injected vehicles you will find a sensor that measures intake air temperature. You will need to refer to your factory service manual to find its location.
At any rate, it is very typical to find the IAT sensor mounted inside the intake plenum that is very often heated heavily by coolant and the cylinder head. This is fine of course, since the original equipment manufacturer designed it to work this way. However, there is a way to "trick" the engine computer into thinking that the incoming air is a little cooler than it really is, and therefore get the ECU to advance the timing a small amount and increase fuel supply at the same time.
In most mildly modified vehicles, this will create a more desirable fuel and ignition map and create a few extra horsepower.
In order to perform this mod, simply locate the sensor and remove it from the intake manifold. Fill in the hole with JB weld and proceed to remount the sensor somewhere in the intake arm. Seal everything up well, and you're done.
Modification Number Four: Synthetic Oil
In the past 3 years I have been running various types of oils through my engines and have found that for the most part - all oils are the same, power wise. However, Synthetic oils definitely make more power over standard "dino" oils. In fact, I have consistently seen anywhere from 2-3hp across the rev range from using a true synthetic versus a standard oil.
Therefore, next time you change oils, switch to synthetic. Even on a high mileage engine, it works wonders. It is also a far better lubricant and protector of your engine.
Modification Number Five: Increase H2O Ratio In Coolant
If it weren't for corrosion and freezing concerns, automotive makers would use pure water to cool your vehicle. Straight water cools better than coolant any day of the week, and a cooler engine is always going to produce more horsepower.
Instead of a typical half and half ratio, try 40/60. However, NEVER use pure water, as this may cause premature corrosion which will cause a costly repair bill. You may also try water wetter to further enhance the effect, but be cautioned that water wetter should only be used for track purposes.
i want to index my plugs however i have no idea where the "intake side of your cylinder head" head is. could someone post a pick showing which way to set the plugs? and has anyone ever insulated their fuel lines?
