Fuel
Old Jun 6, 2009 | 12:38 PM
itsthecaptain's Avatar
Fuel
Could i put the subaru 440cc injectors and the Walbro 255 pump in my 05 es without a turbo? would i need a piggyback?
Old Jun 6, 2009 | 12:50 PM
bcollinstex's Avatar
I'm curious, why are you doing this without a turbo?
Old Jun 6, 2009 | 12:53 PM
senate6268's Avatar
+1
No need to install those without the fuel needs of a turbo setup.
Old Jun 6, 2009 | 01:12 PM
Haha...i'm actually planning on adding a turbo at some point. My car has been sort of deadening at times during acceleration....and it feels like fuel. So i was wondering if i could do the fuel upgrade prior to the actual turbo install, or if i had to +T it first is all.
Old Jun 6, 2009 | 01:31 PM
senate6268's Avatar
Then get a wideband and do some tuning for fuel/ignition. Lancers do have a flat spot that is easily smoothed out with EcuFlash.
Old Jun 6, 2009 | 01:33 PM
White_KnightOZ's Avatar
I am all about doing as much as you can for the turbo set up, before you actually drop in the turbo, but i wouldn't really mess around with the fuel before the full install. it would just cause you to run suuuper rich, esp if a Walbro and 440cc injectors are all your going to be running. you'd be getting like 5 miles a gallon. Try some of that fuel line/injector cleaner they sell at auto stores, i use that stuff like once every 3-4 months to clean my system out.
Old Jun 6, 2009 | 01:35 PM
whats a wideband?
Old Jun 6, 2009 | 01:38 PM
A nifty gauge that tells you your air to fuel ratio, so you can see when you are running too rich, and ECU flash is for tuning yourself back down to a ratio more around 12:1 so you dont start frying your engine
Old Jun 6, 2009 | 01:48 PM
ambystom01's Avatar
No, install them at the same time you do the turbo.
Old Jun 6, 2009 | 01:52 PM
nice. i'll check it out thanks guys.
Old Jun 22, 2009 | 06:13 PM
sheezy'sES's Avatar
i agree with everyone above. add the fuel mods the same time as the turbo. have someone fix your fuel problem first.
Old Jun 24, 2009 | 09:29 PM
*02Lancer*'s Avatar
I would use the injector cleaner and see if that fixes it first. And if you cannot reflash your ecu and monitor whats going on i would just wait till turbo to put bigger injectors in but if you can monitor and correctly sey your fuel i dont see why you cant put them in when your still NA.
reliablefr
18
Aug 30, 2012 11:46 PM
06RS
Jul 11, 2007 06:57 PM
