boost and the 4b11
Old Mar 26, 2010 | 04:43 AM
dadsgts's Avatar
boost and the 4b11
Getting ready to bolt on my turbo and wanted to get some advice. I'm using a evo x turbo min amount of boost is 11psi. do you think the stock compression using 93 octane would hold up or should i run 100 octane?
Old Mar 26, 2010 | 05:43 AM
yitzac1990's Avatar
11 psi on stock block?!?! i was running 10.....
Old Mar 26, 2010 | 05:52 AM
dadsgts's Avatar
boost
did the engine blow up on you? what octane did you use?
Old Mar 26, 2010 | 05:57 AM
EngRWW33's Avatar
Too much boost, no matter what octane rating gas you are using. VERY DANGEROUS.
I would run 8-9 MAX! Curious as to why you have to run a min of 11psi on?
External wastegate + Manual boost controller! Do not use the internal wastegate with the Evo X turbo. Or get the ralliart turbo. I'm sure you can get one + cash for the X turbo you have.
Old Mar 26, 2010 | 06:15 AM
dadsgts's Avatar
external wastgates are just soo much money..lol. ralliart turbo wont bolt up to the evo x manifold which means i have to completely redo my whole setup. what about lengthing the actuator arm to lower the boost?
ant_turbo
Oct 30, 2007 04:54 PM
sti killer 187
Sep 10, 2006 07:56 PM
Jeff_Jeske
19
Aug 9, 2006 09:26 PM
silvrevo
Feb 16, 2004 01:53 PM
davidw333
May 19, 2003 11:11 AM
