Intake and Exhaust Questions
Old Nov 12, 2010 | 10:50 PM
M@verik's Avatar
Originally Posted by bigjay10
-10 I know how hot air affects the engine, Mr. Einstein. (voice of caveman)"Hot air bad, cold air good." What I meant was if hot air is so bad why even bother with an open air intake system if its just gonna suck in hot air bad. Everybody might as well stay stock then. If you was not gonna bother then why even respond, M@vedik.
Ah the caveman is onto something! Hot air is less dense, meaning lower masses of oxygen per unit volume than if it were cold. Now u need oxygen in the combustion process to make power. See the link? And yes u are correct open air intake systems are worse then stock (depending on location and application). For instance a SRI with a cone in the engine bay would probably lose u power. However if u shield it away from engine heat then it is a different story. Also a CAI is not shielded, but due to its location receives torrents of cooler outside air, thus having the possibility to make more power.
To explain this in simple terms I pose u a question. How much easier is it to breath on a winter's day than during a heatwave? Now u need to link that answer back to why an internal combustion engine needs oxygen.
Now that is just with regards to air temperature without looking at the diameter of the air intake, airflow velocity, pumping losses, smoothing, distance, route etc.
Getting the picture?
Now go make some fire
Old Nov 14, 2010 | 10:20 AM
bigjay10's Avatar
Well couldn't you just remove the right side of the stock air box and secure the filter to the left side of air box? Wouldnt that be about the same as the SRI?
Old Nov 14, 2010 | 10:57 AM
M@verik's Avatar
It would, but again u would be exposing it to hot air.
Old Nov 14, 2010 | 01:33 PM
bigjay10's Avatar
So basically CAI is the way to go.
Old Nov 14, 2010 | 01:46 PM
M@verik's Avatar
Exactly
Old Nov 20, 2010 | 06:52 PM
bigjay10's Avatar
Has anyone used the DC sports short ram intake? Horsepowerfreaks have them on sale for 08-09 lancer 2.4L for $148.85. Didn't see anything in search about this brand of intake. Good deal?
Old Nov 22, 2010 | 12:44 PM
M@verik's Avatar
Havnt heard of it.
Kato
Canadian
Apr 14, 2012 05:45 PM
funkad3llic
Jul 29, 2010 09:07 AM
raytrix
Aug 15, 2009 10:01 AM
Speed Element
19
Feb 27, 2009 12:57 PM
reggiesd
19
Feb 24, 2009 12:44 PM
