Flywheel Question
Old Sep 11, 2010 | 01:50 PM
brutus.nova's Avatar
Flywheel Question
Gents or Ladies,
I am changing the clutch out of my 2003 Lancer OZ Rally and I took the flywheel off and in the excitement i forgot how the three small plates that were in the center of the flywheel went. If anyone has a PDF of the Engine Manual please let me know. I am stuck til i figure this out.
Thanks,
Justin
Old Sep 11, 2010 | 04:47 PM
JRR's Avatar
JRR
Originally Posted by brutus.nova
Gents or Ladies,
Thanks,
Justin
senate has them for download. plus i dont think i used them when i did my clutch..as in i mean they would not fit right with the flywheel. mine i bought from rrm (before cough..)and later found out that it was a clutchmasters.
Old Sep 12, 2010 | 12:57 PM
Thanks I PMed Senate asking for his assistance with the matter. Now I am wondering how to blead the clutch fluid on the lancer. I see the fluid comes out of the same resovoir as the Brake Fluid so I am kind of curious how this works. So if anyone else has experience with this please let me know.
Justin
Old Sep 12, 2010 | 01:03 PM
JRR's Avatar
JRR
Justin
#1 thing....keep it full when bleeding. since it all works off the same for the clutch and brake, air bubbles suck...
but you can do it 1 of 2 ways. if your alone you can gravity bleed it. it will take longer but just crack open the bleeder and let her flow for a bit then try it with the bleeder closed. or if you got a buddy available and a bungee cord that would be ideal. wrap the bungee around the pedal and your buddy push in the pedal. at the same time as hes pushing out you open the bleeder. close the bleeder and have him pull up on the pedal/bungee contraption
josh
Old Sep 24, 2010 | 12:47 AM
Seifer780's Avatar
OR you can have someone on the brake line end bleed brakes, tighten the light, add fluid and have you brake accordingly.
Just sayin.'
