Vision Imports Quad Throttle body
Old Nov 28, 2003 | 11:35 PM
IUP200's Avatar
Question Vision Imports Quad Throttle body
hay Guys,
has anyone taken a look at these yet, and has anyone installed one yet...
http://www.visionimports.com/MTB.html
heres what they claim on the web site.
"The latest performance development is the Quad Throttle body which has basically been taken straight from the Super Touring Race car to your road car. If your looking for serious power gains the quad would have to be one of the best modifications you could ever make. With a performance gain of around 40 - 50%, which is extremely good bolt on power gain for a naturally aspirated engine, you are way in front when you compare the price to a Turbocharger and the additional engine modifications that need go with it.
The Quad system comes complete with a fully programmable computer so that the engine can be tuned for maximum performance. The other advantage of having a programmable computer is that the car can be tuned to suit any modification that you make at any time. The assembly is handmade from billet aluminium and incorporates a throttle position sensor for accurate fuel and ignition control.
The induction noise is unbelievable - no kidding it sounds just like a Super touring car. (Utilizing individual air filters instead of carbon fiber air box and single ram pod filter assembly)
Together with a modified camshaft, exhaust, extractors and ported heads you could expect up to a 70% increase in horsepower
. As an example, the development car which is a 1.5L SOHC Excel (12 valve) should produce around 115 kw (153 hp) to 125 kw (166 hp) which is up from standard 65 kw (87 hp). Initial Dyno runs have resulted in 112 kw (150 hp) with continued fine tuning to follow.
This kit can come supplied with either a carbon fiber air box or K&N Large filter, throttle bodies and intake manifold. We can also supply a programmable computer additionally if you don't already have one. It is not really possible to run the vehicle without some form of computer modifications
We supply and recommend the Haltech E6K system. No other system provides as much value for money nor the superior programming ability.
Kits are now available for 90% of all Mitsubishi's and with our new manufacturer prices have dropped significantly so that most people can afford to purchase one of these units. These can be converted to suit a turbo / supercharger application additionally although this would require some extensive modifications to do so. Pricing for this application is approximate only. "
Old Nov 28, 2003 | 11:37 PM
Stumpy221's Avatar
been talked about run a search
Old Nov 28, 2003 | 11:47 PM
ghostrider's Avatar
We had a good discussion on this already.
