2002 OZ Rally oil leak
Old Dec 10, 2010 | 12:32 PM
ozrallyevo's Avatar
Question 2002 OZ Rally oil leak
i have a 2002 lancer oz rally and i jsut got it about 2 weeks ago. and i noticed that it has a moderate oil leak. the whole front (underneath the header) of the motor is basically coated as well as the underside of the motor. i was wondering if there are any common problems with these motors like leaky cam seals or something like that. please help. thank you
Old Dec 10, 2010 | 03:29 PM
JRR's Avatar
JRR
simple answer no. you just need to make/get a new gasket. go to you local auto parts store and get a new oil pan gasket or some black rtv silicone and make your own gasket. that will solve your problem
josh
Old Dec 11, 2010 | 06:55 PM
ozrallyevo's Avatar
josh
what i was saying is i dont know why its leaking. if it was the oil pan gasket then why would basically the whole motor be coated?
Old Dec 11, 2010 | 08:33 PM
JRR's Avatar
JRR
what do you mean all over? it could also be a head gasket if its "all over." i wouldnt rule that out.
Old Dec 11, 2010 | 08:40 PM
02-Lancer-Es's Avatar
These cars commonly leak from the valve cover gasket which would make everything dirty with oil .
Old Dec 29, 2010 | 03:00 PM
turbotsi's Avatar
My money is on the valve cover gasket, its very common on most mitsus for the valve cover to leak. and that would have the oil running down the front of the engine. Change that, clean up the engine and go from there
Old Dec 30, 2010 | 07:09 AM
ozrallyevo's Avatar
Thumbs up
Thank you. That answers my question perfectly. I will check that out
Dank_oZ rally02
Lancer Engine Tech
Oct 9, 2018 11:16 PM
Dank_oZ rally02
Lancer How Tos / Installations
Jul 9, 2016 07:59 PM
Jgreen13
Oct 7, 2015 12:02 PM
Hanzo OZ
Sep 29, 2012 09:35 PM
LancerPride
Aug 13, 2008 03:55 PM
