RPW Header for 4B10 (almost 4B11)
Old Feb 14, 2011 | 06:46 AM
Raptor58559's Avatar
Hey,
I know there are many threads about this topic but I didn't found an good answer.
I read about the dramatic with 4-2-1 vs. 4-1 and that a 4-1 with long primary pipes can gain more torque than a header with short ones (and is compareable to a 4-2-1).
I want to buy a header from RPW but I'm not sure what to take.
My Lancer has a 1,8 liter machine which is almost the same like the 4B11.
I first wanted to take a 4-2-1 because of low and mid RPM gains...
The 4B10 definitely needs more torque at these levels.
http://www.rpw.com.au/shop/index.php...emart&Itemid=1
But they told me a 4-2-1 would be too restrictive at higher RPM.
(I also want to add the EVO X camshafts)
So they told me to take this one....
But their description sounds like there are no impressive gains with this header.
I don't know what to take...maybe a header of an other manufacturer.
I need your help!
thanx
Michael
Old Mar 24, 2011 | 12:34 AM
taaj's Avatar
RPW headers are a direct bolt on and makes your car breath and perform better from ridiculously designed stock!
Old Apr 26, 2012 | 12:24 AM
evo.maniax's Avatar
I need some ..
i just bought the RPW 4-2-1 header for my lancer 4B10 2010 (european) and received it yesterday. Now i have a Problem because my car has two catalytic converters , two O2 sensors. you would call my car a "PZEV" model in california...think thats right.
to say it with images:
The new header (no place for the front o2 sensor):
My lancer:
Lancer 200X-2009 :
this is how it looks under the car:
O2 Sensor front
the new manifold should bolt directly up to the original flange point on the stock catalytic converter. and there is the problem: what to do with the front o2 sensor now ?? Has anyone already had the same problem ??
my car:
Old Apr 26, 2012 | 11:29 AM
LiX's Avatar
LiX
Looks like you didn't read all specifications before buying..
You can drill for a bung just before the flex section.
danfalcas
Oct 12, 2014 05:46 PM
Zerofour1223
Lancer Engine Management / Tuning Forums
Apr 22, 2014 02:08 PM
amer.g
Lancer Engine Tech
May 17, 2012 07:51 AM
lonestarevo83
Jan 10, 2012 02:54 PM
aussie027
Lancer Engine Tech
11
Aug 25, 2010 04:03 PM
