spec question
Old Apr 27, 2011 | 11:10 AM
08bluegts1's Avatar
spec question
How can i tell if my car is fed spec or low admissions?
Old Apr 27, 2011 | 12:58 PM
villero1834's Avatar
If u have a dual cat , check the exhaust manifold theres one and then check the ehxaist pipe there is another cat and the resonator if u have all 3 then u r a pzev
Old Apr 27, 2011 | 01:45 PM
yitzac1990's Avatar
actually there are 2 resonators. So if you have 2 cats and 2 resonators, its PZEV. 1 cat and 2 resonators, FED. the second cat is located basically right after the manifold, where the runners meet. I believe there is also an O2 sensor in that cat as well, so you could easily tell if it was a cat.
The other way to tell is to look at the sticker/plaque on the passenger side of the car, when you open the door on the lower B-pillar. I forget the scheme, but a certain letter/number would mean FED, and a different letter/number would mean PZEV.
Old Apr 27, 2011 | 02:47 PM
08bluegts1's Avatar
Well the motor is out of the car and wanted to know if there was a difference
Old Apr 27, 2011 | 04:34 PM
No diff in the engine but i know i have a pzev and i had 2 cats and 1 resonator now i dont have only a resonatot with the o2 bung so it wont trow cel
megamind
Mar 19, 2017 08:35 AM
bryonboals
Oct 14, 2012 02:03 PM
EvoRs
Feb 9, 2005 06:04 AM
Austin_
Jun 3, 2003 08:22 PM
