question concering turbo
Old Dec 29, 2003 | 02:48 AM
thereasonsf3's Avatar
i am have and exhaust and i'm getting a SRi, will these parts be pointless if i got turbo? or will they just ake it ore powerfull?
Old Dec 29, 2003 | 03:26 AM
SiRLanZer's Avatar
From: Originally from California and stationed in Virginia.
if youy put turbo on the SRI is useless.
Old Dec 29, 2003 | 03:29 AM
JVlancer's Avatar
your fine, you will get more power because of your exhaust.. and you can also use your SRI - depending on how you have your piping made but they will both work
Old Dec 29, 2003 | 06:56 AM
HobieKopek's Avatar
You can most likely reuse the filter if you want. If you're definitely going turbo...well...the SRI isn't the best investment.
Old Dec 29, 2003 | 08:11 AM
Boeturbolancer's Avatar
Having exhaust done will only help on turbo applications... as for the SRI you'll be able to reuse it if it is the RRM SRI and you get the RRM turbo kit.
Old Jan 1, 2004 | 12:25 PM
cdyancey's Avatar
having a better exhaust does NOT only help turbo applications.
anytime you help an engine breath better whether it is inhaling or exhaling, it frees up horse power.
Old Jan 1, 2004 | 02:24 PM
Didn't say it only helps on turbo's... said it will only help meaning it can do no harm for turbo applications. Better exhaust is better no matter what way you are going... NA/Turbo.
darkblues24
Mar 30, 2016 07:11 AM
kakarot305
Dec 9, 2010 12:25 PM
evojanoy
May 6, 2010 10:35 AM
kungfugirl
Apr 22, 2008 07:32 PM
Evo11V
Oct 15, 2003 06:56 PM
