Gas Mileage w/ Mods
Old Jan 23, 2004 | 07:03 AM
Rawdog5581's Avatar
I am currently running the Greddy Cat Back, Injen CAI, and Test Pipe. If anything I noticed better gas mileage as I added these Items. I drove from NJ to Myrtle Beach this summer at 12:00 midnight and got almost 400+ miles to the tank. Not bad at all. It was nightime and the air was clear. Plus I was cruising around 90 the whole way.
Old Jan 23, 2004 | 07:08 AM
IILANCERII02's Avatar
thanks for all the replies
but another question has comed to mind after someone said something about a burned out 02 sensor.
Since im running the kamikiazke header, and there is no o2 sensor, could the ECU just be confused and adding more fuel that it should thus cuasing bad gas mileage and some other problems?
Old Jan 23, 2004 | 07:23 AM
Rawdog5581's Avatar
That could be the problem since you don't have an O2 Sensor. It's probably making your ECU all confused.
Old Jan 23, 2004 | 07:29 AM
Blacksheepdj's Avatar
Yup. With no O2, your car could very well be pumping extra gas into the chamber and running rich (that's what my car did). When you combine that with the open system you have, you could easily be LITERALLY spitting gas out the tailpipe. But that's just a guess, I'm no mechanic.
Old Jan 23, 2004 | 07:30 AM
lol damn ECU!
well, since there is no o2 sensor hole! only dis - advantage of kamikaze. But, i've kind of been thinking if i get the MIL Elimenator, will that tell the ECU that the o2 sensor is working properly or will it just tell it whatever so the SES light turns off?
Because in the long run i just want the SES light to turn off while having the o2 sensor working properly.
Old Jan 23, 2004 | 07:32 AM
ya i think your right, because i've noticed gas in the muffler before.
any suggestions of what to do or the best option would be?
Old Jan 23, 2004 | 07:44 AM
Best option... hmmm.
To me, the best option would be to find a high-flow cat that lets you plug in the O2 sensor (Buschur maybe?). You'll get back some backpressure and not waste as much gas. And having the O2 sensor will cause you to stop running so rich. I think between the backpressure and the functioning O2, that would solve a lot of the gas issue.
Bear in mind, this is my opinion, I could be wrong.
Old Jan 23, 2004 | 08:39 AM
but the cat isnt the problem, i have that o2 plugged into the test pipe, its the Header o2 sensor that i have a problem with.
Old Jan 23, 2004 | 08:41 AM
Oh. Well, I still recommend a high flow cat instead of a test pipe just for backpressure. As for the first O2 sensor, I don't know what to advise about that - I'll be sticking with the stock exhaust manifold until I get some cash.
Old Jan 23, 2004 | 08:44 AM
alright, thanks blacksheep for all your help!
maybe once it gets warmer ill post a --- trade test pipe for hi-flow cat thread lol
Old Feb 1, 2004 | 05:13 PM
OZBOTS's Avatar
Talking
**** my dodge p/u truck gets beter then 170 and it's a 360cid. (No it's not a hemi)
Old Feb 2, 2004 | 07:41 AM
lol, i just tested it and i got roughly 155miles per the tank.
i guess its not as horrible as i thought. i mean you get 170 with your tank and your tank on your p/u truck is probably a bigger gas tank, keep in mind we have small little gas tanks.
my friend gets 170 with his firebird and he has a 16 gallon tank,so its all about the same.
Old Feb 2, 2004 | 08:23 AM
Earl Needham's Avatar
Veteran: Air ForceVeteran: Marine Corp
You should be able to take the header off and get a shop to weld a bung in the header to fit the O2 sensor.
Old Feb 2, 2004 | 08:38 AM
HobieKopek's Avatar
Yup, and it shouldn't cost much either. $10-20 tops.
Old Feb 2, 2004 | 02:18 PM
alright, that might work, or i might just get a MIL Eliminator, because i didnt put the header on, so i ... well i know how to get it off im not that stupid, but i dont want to ahve to hassle with it again.
