RRM ECU Piggy Back Install Help!!
Old Feb 24, 2004 | 07:03 PM
2002OZ's Avatar
Ok I am on the last thing, the vacume hose, it says it need to T into the fuel pressure regualtor, well I have no idea where on the intake manifold that is. Can anyone help. Thanks
Ryan
Old Feb 24, 2004 | 07:15 PM
2002OZ's Avatar
Anybody know this?
Old Feb 24, 2004 | 09:58 PM
KillahB's Avatar
IS your question where the intake manifold is??
First of all, give us some time bro. Your second post was less than 10 mintes after the first. Dont worry, give us some time and we wil lget to it.
The FPR should be on the left side (passenger side) of the fuel rail. It looks like a little bell thingee at the end of the rail. Dont know how else to describe it.
Old Feb 24, 2004 | 10:08 PM
rhyzin's Avatar
https://www.evolutionm.net/forums/sh...threadid=28692
if you ever need pics on what stuff looks like, check the "how to" section. you should be able to find the fpr in this link.
Old Feb 25, 2004 | 05:32 AM
jozilla69's Avatar
Alright, you know where the TB connects to the intake mani look on the opposite side and you'll see a single vacuum line coming out of the intake. If you trace this line it goes directly to the fuel regulator (aka "bell type thingy" hahaha). Pull the end off the intake and put in the T section, cut a smalll peice of the supplied vacuum hose and connect the T back to the manifold. Next connect the line coming from the PB that goes through the firewall to the T. Shorten this line if necessary, I had to on mine just to keep it out of the way of moving parts.
