How much horsepower can I get out of a 4g64?
Old Feb 2, 2014 | 10:20 AM
purpledranktown's Avatar
Nd
Old Feb 3, 2014 | 02:53 PM
I guess the 4g64 is really slow
Old Feb 13, 2014 | 03:32 PM
02modlanceroz's Avatar
The 4g64 is a way better platform than the 4g94. Lot more potential and aftermarket support. But the question is kinda irrelevant. Making power depends on a lot of different things. Essentially, how much do you wanna spend?
Old Feb 16, 2014 | 06:20 PM
Archlegan's Avatar
The g64 has a cast iron block, as apposed to the g94's cast aluminum. In addition, the crank comes forged stock. That being said, there's a lot more potential for FI; rods from a g63 can be used as well.
Also, a g63 DOHC head swap can be done, allowing you to use the intake & exhaust manifolds as well as valvetrain from an EVO.
Take a look on club3g.. There's some members pushing really appealing numbers with this engine.
Old Feb 16, 2014 | 06:27 PM
Ralliart09er's Avatar
Friend of mine had a 4g64 in his dsm. Ran a 3076r and was pushing 430whp if that helps. Heard they're notorious for having head gasket issues. My friend had that problem as well. Keep an eye out for that n the best of luck!
Old Feb 16, 2014 | 07:03 PM
Migsubishi's Avatar
Fully built and boosted, with an evo head?
Check this out ~> https://www.evolutionm.net/forums/ev...stock-ecu.html
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
