Crankshaft Sensor 2002 Mitsubishi Lancer
Old Feb 11, 2016 | 07:48 AM
onix175's Avatar
Question Crankshaft Sensor 2002 Mitsubishi Lancer
Hi all,
I am replacing my Crankshaft Sensor, While removing the lower belt cover. I found a bold behind the Crank Pulley Which I cant get to unless I remove the Pulley.
Does any one knows if I removed the Crankshaft Pulley will effect the Timing belt? Because The Belt was changed 4 month ago. So all is good in this part and don't want to mess with the timing belt. So please I need to know if the Crankshaft Pulley will effect my timing belt or not?
Thanks and regards.
Old Feb 18, 2016 | 10:16 PM
Complink's Avatar
Originally Posted by onix175
Hi all,
Thanks and regards.
If you remove your crank sprocket you will have to make sure the timing marks line up when you put it back. Now you can remove the crank pulley and it won't hurt, as long as you leave the timing belt on.
Old Feb 19, 2016 | 04:54 AM
onix175's Avatar
Thanks you so much
slvrevosd
Mar 14, 2016 01:33 PM
CeliOnce
19
Jun 25, 2015 07:48 AM
05EV08
Dec 17, 2014 06:54 PM
Fabillionaire
Apr 10, 2013 09:09 AM
LGshow19
Jun 9, 2012 11:19 PM
