idle low then dies?
Old Apr 29, 2016 | 05:00 PM
jb988's Avatar
idle low then dies?
My 03 es is starting to die when I'm at like a light or just parked with. It idles real rough then just drops off. Any ideas?
Old Apr 29, 2016 | 05:59 PM
jb988's Avatar
Any help appreciated. I'm at work as a delivery driver and it sucks right now. It happens also I go into a turn with out giving it gas.
Old Apr 30, 2016 | 06:36 AM
CrAnSwIcK's Avatar
pinch one of the purge solenoid valve hoses and see if it picks up.
Any trouble codes?
Old Apr 30, 2016 | 10:38 AM
jb988's Avatar
I'm sorry but I'm not sure what a purge solenoid is. Where is that? I'd assume on the intake side
Old May 1, 2016 | 05:52 AM
CrAnSwIcK's Avatar
yeah, it's near the EGR solenoid, right in the middle between the valve cover and the intake manifold, if you're standing in front of the car looking at the engine, the EGR solenoid is on the right, the purge solenoid is on the left, right beside the PCV valve which is the short hose that goes between the valve cover and the intake manifold...looks like this:
also check for any other vaccum leaks...clamps on the intake tube, MAF sensor housing, throttle body, and any rubber hoses connected to the intake manifold.
Old May 2, 2016 | 09:47 AM
jb988's Avatar
The problem just went away? So confused
Old May 2, 2016 | 09:58 AM
Epyon's Avatar
Did you have a bad batch of gas?
Old May 2, 2016 | 09:59 AM
jb988's Avatar
I'm not sure, I have been using supreme recently and nothing else
Old May 2, 2016 | 03:57 PM
CrAnSwIcK's Avatar
unless your ECU is tuned for supreme, you're wasting your money.
Old May 2, 2016 | 09:31 PM
jb988's Avatar
Well now that I have a tactrix cable I can tune for supreme?
Old May 3, 2016 | 11:34 PM
CrAnSwIcK's Avatar
sorry, but your previous post struck me as "i use premium because it's better"...premium fuel could still become contaminated..."bad gas" doesn't mean low octane...
of course you can tune for whatever fuel you'd like to use...though depending on how aggressive you tune, you would have to strictly use that fuel brand/grade to keep consistent results, with minimal risk...
Old May 4, 2016 | 09:36 AM
jb988's Avatar
Oh ok. I still have a lot to learn with ecuflash and evoscan
Old May 10, 2016 | 11:20 PM
jimbo74's Avatar
Veteran: Air Force
it is an 03 es, are you modified at all?
Old May 11, 2016 | 02:23 PM
jb988's Avatar
Catback. And short ram intake
Old May 11, 2016 | 06:49 PM
CrAnSwIcK's Avatar
either your MAF or IAC is pooched or you have a vacuum or emission leak is my guess.
