ECU's
Old Aug 19, 2002 | 05:37 AM
newozlancer's Avatar
ECU's
anyone know if there are (performance ECU) chips out there for the Lancer?
Old Aug 19, 2002 | 05:45 AM
pjal84's Avatar
If you took the time time to run a before you started a , people would probably be more inclined to since they didn't feel they did all the work by themselves.
And the answer is no. You could always get a Motec, GEMS, or something of the sort. Because bolt ons need that kind of processing power ($$$$) . High boost turbos with bigger injectors, an uprated fuel pump and different ignition timing could use it though. At most, people are going to need an AFC for their mods and I'm talking stuff with head work etc.
