-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-56/)
-   -   ECU's (https://www.evolutionm.net/forums/lancer-engine-tech/7332-ecus.html)
newozlancer Aug 19, 2002 05:37 AM
ECU's
anyone know if there are (performance ECU) chips out there for the Lancer?
pjal84 Aug 19, 2002 05:45 AM
If you took the time time to run a https://www.evolutionm.net/forums/images/top_search.gif before you started a https://www.evolutionm.net/forums/images/newthread.gif , people would probably be more inclined to https://www.evolutionm.net/forums/images/reply.gif since they didn't feel they did all the work by themselves.
And the answer is no. You could always get a Motec, GEMS, or something of the sort. Because bolt ons need that kind of processing power ($$$$) :rolleyes: . High boost turbos with bigger injectors, an uprated fuel pump and different ignition timing could use it though. At most, people are going to need an AFC for their mods and I'm talking stuff with head work etc.
