Cat replacement question
Old Apr 7, 2004 | 07:50 PM
pskelly86's Avatar
I was recently reading about people getting exausts for their Lancers and how the Lancer has two cats. I also read that most replace one cat with either a test pipe or a high flow cat. I was wondering if its possible to replace one cat with a test pipe and replace the other with a high flow cat? If so, is it extremely loud? I figured if it was a high flow and a test pipe instead of two test pipes it would lessen sound slightly, asumeing its possible that is...
Old Apr 7, 2004 | 07:53 PM
SIMSSEGA's Avatar
first of all you can only replace one cat with a down pipe/ hi flo cat(second one also only one under the car). The other one to my understanding is in the header. So to replace the first cat with a free flowing exhaust you will need to get a new header.
Old Apr 7, 2004 | 08:07 PM
XTXANDY's Avatar
With a high flow cat and a downpipe it would probably be quite a bit louder than with both cats. Probably almost as loud as no cats. Thats just my opinion from what i have experienced.
Old Apr 7, 2004 | 08:11 PM
SIMSSEGA's Avatar
Um...you cant put a hi flo cat and a down pipe. You can put one of the other in for the second cat and you can just get newheaders to replace the first one. And yes its loud *** hell with no cats InsANE!
Old Apr 8, 2004 | 09:33 PM
sadude's Avatar
hold up...I am confused
if I were to lets say intsall a kamikaze header, then my first cat would be gone
know can I replace the remaining cat with a high flow cat?
if I do replace it, how do I accomadate the 2nd O2 sensor?
thanks
Old Apr 8, 2004 | 09:45 PM
lancerj's Avatar
if u replace the header and first cat sadude, u have a choice of leaving on your second cat (downstream) or going for a testpipe. heres one on ebay for sale-
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
i am trying to get one, i'll let u know how it goes. and stay off the trees! j/k
Old Apr 8, 2004 | 09:46 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Not sure about the Kamikaze, but some other headers (RRM and I think RPW) have a place to put the first O2 sensor (although you need a resistor to make it read what it wants to read), and any emissions legal hi-flo cat will have everything needed for the second sensor.
Old Apr 9, 2004 | 06:18 AM
sadude's Avatar
well teh kamikaze header I am getting does have a bung for the first O2 sensor, so that problem is solved
sorry for being so dumb but what is the stock size for our exhaust piping? if I were to get a racing/hi-flow cat off of ebay I should be cool since teh 2nd O2 sensor bung will be there
lancerj...can't do the test pipe since my kamikaze will remove the first cat
thanks guys
Old Apr 9, 2004 | 09:54 AM
Blacksheepdj's Avatar
No, you are thinking of a test pipe. The downpipe is the pipe that connects the exauast manifold or header to the cat. Therefore, the cat actually bolts to the downpipe. Sorry if that's stating the obvious, but I don't wanna confuse anyone.
Old Apr 9, 2004 | 10:05 AM
lancerj's Avatar
im just clarifying this sadude, the first cat we are all talking about is in the exhaust manifold. the kamikaze header will replace that. it also comes withe the downpipe/flexpipe that is then connected to the SECOND cat. i think our stock piping is about 1 and 3/4 inch. correct me if im wrong
Old Apr 9, 2004 | 11:36 AM
Well, from looking in during removal, I'd say the stock downpipe is roughly . . . 2mm.
Just kidding.
Old Apr 10, 2004 | 12:55 PM
sadude's Avatar
1.75", damn that is small, even the upgrade piping of the header is the same.
i guess i'll have to wait till I pick it up tonight and then go from there
Old Apr 10, 2004 | 09:01 PM
sadude's Avatar
okay update, just got the kamikaze header. its a 2.5" outlet, so should I get the same size racing cat or should I go a step down?
also any advantages to having all 2.5" as opposed to the step down?
thanks
Old Apr 10, 2004 | 09:29 PM
josh930's Avatar
yes.....too big of an opening in your exhaust piping will cause you to lose torque. 2 1/4 exhaust piping is the right spec for our car. And just a quote to keep in mind...."bigger is not always better"
chris4b11t
Nov 21, 2013 06:16 AM
CDrinkH2O
14
Oct 9, 2011 11:22 PM
OZ_racing
Lancer Troubleshooting
Apr 9, 2010 07:04 PM
villero1834
Lancer Engine Tech
May 14, 2008 01:01 PM
DynoFlash
36
Jun 16, 2007 03:49 PM
