nooB question on 2nd cat
Old May 4, 2004 | 10:47 PM
TeamNeXusOz's Avatar
i current am a proud owner of a kamikaze header...though my only complaint is the damn CEL now i read some where befre that they turned thier cat around toget rid of the CEL...is that possible? and second would it work?...
Old May 5, 2004 | 03:01 AM
ghostrider's Avatar
I think people that have tried this ran into the problem that the wiring for the 2nd o2 sensor is too short to flip the 2nd cat around completely.
Old May 5, 2004 | 09:05 AM
anyone else?
Old May 7, 2004 | 05:24 AM
livelyjay's Avatar
Is there an O2 sensor bun up on the header for the first O2 sensor to go in? If I remember correctly the first runs of Kamikaze headers did not have these buns. Turning the cat around actually makes some sense. The reason why the CEL comes on is because the second O2 reading is off of normal. Turning the cat around would give the exhaust gases time to cool more and be depleted of whatever the cat gets rid of. If the wire isn't long enough, you could try making an adapter.
Old May 8, 2004 | 08:53 PM
thats exactly why this question is up there....so has anyone else done this?....extending the wires should be that hard right?
Old May 8, 2004 | 10:02 PM
SIMSSEGA's Avatar
not sure if you have to because i have read of people just doing it with no problem. When i was putting my testpipe in the little stopper that goes around the wires just poped out so i bet that you can just uptt that out and see where that gets you. You shouldnt have too much trouble with it though.
Old May 8, 2004 | 10:04 PM
is it going to change the airflow at all or no?...and how is it supposed to stay up?
