installing AFC need to check pinouts
Old May 28, 2004 | 09:21 PM
Waggi32's Avatar
Hey, I am working on installing an AFC but I want to make sure that I have the right ECU pins.
This is what I have can you please confirm if these are right:
Power = 26 pin connector the second pin from the right on the bottom of the connector
Ground = 26 pin connector the pin to the right of the the power on the bottom of the connector
RPM signal = 12 pin connetor the pin 2nd from the left on the bottom of the connector
Throttle position signal = 22 pin connector 3rd pin from the left on the bottom of the connector
Air Flow Signal = 22 pin connector 3rd from the right on the bottom of the coneector
When I am talking about the position of the wire on the connector I am comparing these positions with the positions they would be seen in when looking at a pinout diagram.
Thanks for the help.
