No-CEL header?
Old Jun 18, 2004 | 11:39 AM
Blacksheepdj's Avatar
No-CEL header?
Since our oxygen sensor is so close to the block, do you think anyone will ever make a header that doesn't cause SES?
Thoughts, comments, opinions?
Old Jun 18, 2004 | 11:41 AM
WADADLIG_OZ's Avatar
Mine hasn't and it has been over a year now.
WADAD
Old Jun 18, 2004 | 11:49 AM
Any secrets?
This is important, because now in Ohio if your car throws a CEL, you fail emissions testing. I really don't want to be removing the header all the time.
Old Jun 18, 2004 | 11:54 AM
Z_Lancer_Man's Avatar
WADAD
Which header do you have? Kamikaze or RRM or another? And is it true that when you put on a header, you take off the cats?
Old Jun 18, 2004 | 11:56 AM
It's true that you remove A cat. There are two. One is in the header, the second is the large thing behind the downpipe.
Old Jun 18, 2004 | 12:03 PM
Will you still pass emissions with an aftermarket header?
Old Jun 18, 2004 | 12:12 PM
Viciouz's Avatar
you probably will not pass emissions at all, even tho you might not throw a CEL, u'll definately fail... its cuz the stock exhaust manifold is attached to the Primary Cat that is removed by replacing it with an aftermarket header
Old Jun 19, 2004 | 04:35 PM
I have the RPW header.
It does remove the first cat but since there is no emissions testing here I cannot confirm if the car will pass/fail.
WADAD
Old Jun 20, 2004 | 01:40 AM
ghostrider's Avatar
My RPW header didn't trigger anything either. It finally went off when I had my car disconnected overnight at a show. But that also triggered an error with my emanage so I think the CEL is more due to the disconnected battery than the header itself. I had mine on for over a year with no error.
Old Jun 20, 2004 | 03:00 AM
LancerDriven's Avatar
How much did you guys pay for the rpw header?
Old Jun 20, 2004 | 04:14 AM
ruipina's Avatar
I had the the A cat removed and installed a header about 1 year ago. Immediately the CEL went on. This can be solved by installing a CEL fix or MIL eliminator available at miliminators.com or on the kamikaze header web site. You install this on the O2 sensor closest to the exhaust and you CEL is gone. I am very happy with the result. Probably takes 30 minutes to install
Old Jun 20, 2004 | 02:48 PM
ghostrider's Avatar
I paid around $300 shipped for mine from ozbots a long time ago. The race design header (which wadad and I both have) retails for over $400 though.
Old Jun 22, 2004 | 05:58 PM
andy's Avatar
When I installed my Header I extended the wires from the first o2 sensor and installed it in the down pipejust before the cat, and the second one after the cat, no CEL.
Old Jun 23, 2004 | 12:50 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Someone told me if you flip the second cat around backwards, it will put the second sensor after the cat, giving it a different reading than the first, tricking it into thinking it's the precat. Not sure if this works, but it still won't be emissions legal.
Old Jun 23, 2004 | 05:05 AM
ghostrider's Avatar
I thought the o2 sensor wire is too short to flip the cat around?
